YS 110 FZ
YS 110 FZ
Hi every one,
I need some advice from anyone knowing a bit about these engines. Well what I have done is purchase a second hand one and not knowing any thing about its history. I dont even know about these engines.
Well I am sure I can get it up and running but what I would like to know is if the cam area within the bearing housing should be making a ticking noise. I think it should'nt but as I said I know nothing about these.
I just hope the motor is not a piece of worn junk. Will wait for a reply before I start it just incase.
Take care all
Take care all
RE: YS 110 FZ
I did not think I would get that quick a response and I have started it ok and boy do they pick up quick. That is going to be some what more powerfull than the os120 pumper I just took out of my plane.
What I did notice is that it would not start on the sugested 1 and 1/2 turn out on the needle. I had to go 2 turns but I am using 10%. Its all I have in the garage. I can not wait to give this plane a try.
Its in a C G extra 300.
Thanks for responding so quickley guys.
My Feedback: (57)
IN
RE: YS 110 FZ
They click. No problem there. Use 20%-30% Nitro with 20% oil. Makes tuning way less sensitive. Stay with the same fuel %'s and the tuning will stay easy. The cam is supported by ball bearings unlike the Saitos. I pop off the rocker cover every 10 flights or so and run some oil down the pushrods just to be sure. The prop I like on it for sport planes is a 16x6.
RE: YS 110 FZ
Well I have been up with the plane. I used yamada 20% and 15x8 prop. It spun to 1060 but I did back it off.
The fuel consumption was very poor. I must admit that I was giving some throttle more so than normal, only because I was amazed at the power.
I am still concerned that there might be a slight problem with it as it used alot of fuel as I allready said but also the mixture screw was 2 and 1/4 turns out. I used 12oz of fuel in about 7mins.
It could do with some more fine tunning but its nearly there and dont think the consumtion of fuel will change that much.
Well can any one tell me if its normal or can I expect better out of it. Here is a link to show what plane it is in now.
http://www.rcuniverse.com/forum/m_24...11/key_/tm.htm
Thanks dobra
Thanks dobra
My Feedback: (18)
OH
RE: YS 110 FZ
I picked up a used 110 FZ. Set HS needle at 1.5 turns out. Put a 15 x 8 APC prop on it. 20/20 fuel. Started it up, let it warm up at about 4000 RPM for 1 minute, then slowy rolled it up to WOT, and my tach was showing over 12,000 RPM. I quickly cut the throttle back to about 4000, richened the HS needle to 2 turns, and ran the throttle back up. Same thing over 12,000. When leaned out it hit over 13,000, then backed it out 4 clicks. Everyting I read says to run the engine at 9500 max. What do I do? Do I use my EPA on the radio to keep the engine down at the 9500 or try another prop? Help please.
My Feedback: (58)
RE: YS 110 FZ
One of three possible answers...... that is one strong 1.10, you took the tach readings under artifical light, or your tach is off. The tach is easy to test, set it to two blade prop and point it at a florescent light about 3 feet away. It should read 3600 RPM.
Let us know what you find.
My Feedback: (18)
OH
RE: YS 110 FZ
Tach is brand new - Hobbico and it reads 3600. Seems to work correctly when I used it on my 46 AX. The engine is mounted on my plane. It was started in the garage about 10 feet from the door on a table I built for my planes. I placed the tach in front of the engine with the sunlight in the background - door wide open. Sunny day. I'll take it to the field next nice day and try again outside. If the engine still runs strong, what size prop should I try next?
My Feedback: (18)
OH
RE: YS 110 FZ
I finally got a chance to fire it up outside this time. Using a 16 x 6 APC this time I was able to get the engine running and everything appeared to be good. It held its idle real well at 2000 and topped out at 9600 backed off of peak about 3 clicks. Seemed to be running just fine, but then I noticed the exhaust came loose. Bummer, didn't have time to remove the cowl and mess with it. Any tips here. I thought I had it torqued down pretty good. Should I use locktite?
My Feedback: (41)
RE: YS 110 FZ
ORIGINAL: nonstoprc
Wrap around the extension pipe with a piece of teflon tape (sold in HomeDepot for pluming) and screw the extension to the engine's exhaust exit, do the same for the muffler. Tight the nut.
I have been using this method on all my YS engines. It works great!
