ZDZ & RCS Support Direct support from Mike Dooley of RC Showcase for all your ZDZ and RCS Engine questions.
RCS 44 b2 twin
Reply
Old 04-29-2018, 12:18 PM
flyingbrian
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RCS 44 b2 twin
I purchased an RCS 44 twin not long ago on RCU I finally got around to test run the motor. Motor idles well and transitions good to Hi throttle.
However I noticed a small amount of oil residue coming from the crank case seam on the top side of the motor between the front case housing and
the rear ( I guess rotary ) housing, between the 2nd and 3rd case bolts from the front of the motor. Do the two case halves require a gasket or a casket
compound like RTV sealant. Can I ignore this small leak or should I attend to it.. If so I will have to disassemble the motor to get to that crankcase joint.
The leaking residue increases with RPM. None at idle and more at hi throttle.
Any suggestions??
Brian
flyingbrian is offline
