ZDZ & RCS Support Direct support from Mike Dooley of RC Showcase for all your ZDZ and RCS Engine questions.
ZDZ Specs - Measured vs. Calculated
Old 01-01-2004, 08:35 PM
kcnelson
Default ZDZ Specs - Measured vs. Calculated
The specs for ZDZ engines (power and thrust) are calculated vs. measured, and seem to be based on the best results with one prop. Is there any source for actual measurements?
Old 01-14-2004, 12:57 PM
Mike Dooley/RCS
Default RE: ZDZ Specs - Measured vs. Calculated
No one that I know of has any true life hard dyno numbers, really not needed or necessary.
