ZDZ & RCS Support Direct support from Mike Dooley of RC Showcase for all your ZDZ and RCS Engine questions.
ZDZ 60 Blueline Props - Advice wanted
Reply
Old 11-27-2005, 06:15 PM
Minch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default ZDZ 60 Blueline Props - Advice wanted
I have just got in larger aircraft/petrol engines and have a ZDZ 60 blueline (JMB Muffler) turning a Menz 24x8 on a Comp. Arf 2.3m extra, engine has had about an hour or so running. It fly's the plane really well, for my style of flying but what prop options do I have? At the moment with a 24x8 menz the engine is doing about 6200rpm, there's plenty of pull, not unlimited vertical but then it is still fairly new. What sort of rpm should I be aiming for when it's had a bit more running, does this engine need to rev a bit more as I notice in the zdz info that max rpm is 8200, should I be aiming for close to 7000 rpm.
If I wanted to go for a carbon prop is there a rule of thumb when converting from wood or is it trial and error.
Nick
Minch is offline
Old 11-28-2005, 10:35 AM
Mike Dooley/RCS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ZDZ 60 Blueline Props - Advice wanted
We suggest starting with a 22x10, then after 4 or 5 gallons of fuel at 32:1, you may transition to a 23x10 or the 24x8 with a synthetic fuel mix of 40:1 for the life of the engine. Typical rpm range- 6500-7000
Mike Dooley/RCS is offline
Old 11-28-2005, 04:09 PM
Minch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike,
Thanks for the advice, will give you suggestions a try.
Regards
Nick
Minch is offline
Reply
Display Modes
