ZDZ & RCS Support Direct support from Mike Dooley of RC Showcase for all your ZDZ and RCS Engine questions.
ZDZ 160 information
Reply
Old 02-23-2006, 12:53 AM
XJet
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default ZDZ 160 information
I've just got a new ZDZ160 and have some questions:
1. The electronic ignition has a connection labeled TTL -- is this a TTL-level output that is triggered each time the ignition fires and can therefore be used to drive a tachometer circuit? (this would be very useful)
2. Can the engine be broken-in on a test-stand without the need to use baffles over the cylinders?
3. What kind of fuel consumption figures can I expect from this engine at full-throttle
4. Why does ZDZ specify 50:1 oil when most other manufacturers are 80:1 or 100:1 ?
5. What range of static thrust can I expect to get from this engine using readily available props?
XJet is offline
Old 03-04-2006, 10:30 PM
XJet
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ZDZ 160 information
Hmmm.. that was a waste of time :-)
XJet is offline
Old 04-14-2006, 04:42 AM
sbu
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey XJET,
sorry I can´t give you so many answers to your questions above, but your message is now 2 month ago and I´m very interested how you have procced. Is this the new ZDZ super 160? If yes, I would apprechiate to get your results from the test stand. I have the previous ZDZ 160,the consumption is appr. 1 gallon per hour. The TTL signal is of the Hall sensor, but for bypassing to a tachometer I would use a galvanic isolation because in case of trouble on the tacho, the ignition will fail and the engine would stall.
Please reply with some of your results, Thanks
Regards
Stefan
sbu is offline
Contact Us Archive Advertising Cookie Policy
