ZDZ & RCS Support Direct support from Mike Dooley of RC Showcase for all your ZDZ and RCS Engine questions.
What cannister for 80rv?
Old 09-22-2007, 09:32 PM
Rick Sowell
Default What cannister for 80rv?
Mike Dooley, or anyone else. what is the best cannister muffler to use on the zdz80rv, it is the blue head version. I need to know what is the best system to install in the new Aeroworks Extra 260 75cc plane. I need to know which header and cannister. the RCS web site only lists headers with 30mm outlet diameter, and cannisters with 25mm inlet diameter, is there some that are not listed? also what size cannister in length and diameter. Thanks in advance. Rick
Old 09-24-2007, 10:21 AM
k_caller
k_caller's Avatar
Default RE: What cannister for 80rv?
Hello,
take a look at Amelung's website which has the details about KS exhaust systems. Here you can find all recommendations for your installation. Most systems are required that you silver solder the tubing. Takes a bit of practice the first time but once you've done it, it's very easy!
http://www.zdz-motor.de/. He does do International shipping and Credit Cards but one word of caution- check the Euro to $ conversion! Right now it sucks for Americans! [>:] But I'm sure someone in the USA does imports of these systems and it might be cheaper. Good Luck.
