Need new WT201 carb for my ZDZ50RV
Hi Mike
In the Gas Engine RCunvierse forum was mentioned that there is a new carburetor used on the ZDZ50 engines. My engine is a little bit old ZDZ 50 RV and I am experimenting with your tuned pipe AMT 50, which by the way is awesome ( I got 7400 rpm on the ground last tine I tested using a Mejzlik 22X8) however I am seeing some transition issues, I would like to try this carb; WT201. Would you have this carb in stock? Would it be compatible with ZDZ 50 RV? Would this carb make easier startings? Thanks |
RE: Need new WT201 carb for my ZDZ50RV
In stock, 54.50.
Thanks |
