ZDZ 80rv downline
I have a ZDZ 80rv blue head with a 26x10 that runs great with good transition on the ground and OK in the air but when I do a large loop and go to idle at the top it will dead stick when advancing the stick at the bottom. I have adj L from lean to rich with same results. It has great power and does not sag on the upline and idles good. Gary
RE: ZDZ 80rv downline
listening
Will it react similarly doing a large outside loop?
not tryed outside loop but the nose down idle down looks like the thing. Then when I throudle up it will quit or at least try to quit.
