RCU Forums
-   ZDZ & RCS Support (https://www.rcuniverse.com/forum/zdz-rcs-support-204/)
-   -   refalcon ignition zdz 80 (https://www.rcuniverse.com/forum/zdz-rcs-support-204/7422366-refalcon-ignition-zdz-80-a.html)
echavi9325 04-26-2008 11:45 AM
Can i use a123 batteries on the falcon ignition
rmh 04-27-2008 11:25 AM
RE: refalcon ignition zdz 80
Which one?
typically the Falkons liked just good , solid amperage 4.8 volt the new ZDZignitions will accept the A123 as is
don't use old crummy tired 4.8 cells get a good pack such as as an Intllect from Cheap Batery Packs .com
low output cells can damage the ignitions
When the original supplier of ignitions , Vlach,first offered ignitions he warned about this.
some latest types are not as fussy but a solid 4.8 is very desireable
the problem is possible voltage drop as the ignition instantly tries to "fill" with current .
that's the simple answer but take it for what it's worth.
echavi9325 04-28-2008 06:50 PM
Thanks for your reply.Its a falcon PC1 60-80 ccm 4.8-6v. I would like to keep all my batteries the same on the plane
once again thank you
Eladio
