HPI Savage XS - general maintenance and upgrade tips??
Hi. I'm new to RC, and have started with an Savage XS Flux Raptor. It's a blast albeit a steep learning curve controlling it. So I have a few questions about maintenance and upgrades, but general advice is welcome. I'm doing a mixture of bashing and general driving I guess, on wet tarmac with a bit of grass and dirt too.
1. What is the best way to dry the model out and prevent rusting around pins etc?
(I'm rinsing with a shower, shaking, partly drying with a hair dryer, then spraying on Nitro Cleaner a couple of times)
2. What "outer" (i.e. non-gears) areas should I keep lubricated and with what?
(A local model shop recommended 20 silicone shock oil around the bearings and axle cups so I've been dropping that on)
3. If I'm upgrading the axles and dogbones, which ones should be upgraded just to HD axles, and which ones should be upgraded to full CVDs?
4. Is there any way to make the controller trigger "stiffer" i.e. require a bit more force to pull it?
(I'm thinking of taking apart the controller and replacing the forward throttle spring with a stiffer one. I found changing the trottle trim wasn't helpful)
5. Is there any way to paint / spraypaint new wheel rims? Do they take polycarbonate sprays?
6. Is it worth upgrading the suspension?? If so should it be softer or stiffer than stock?
7. If I'm upgrading parts in general, which parts is it best to get aluminium for, and which not?
(On the basis that the forces involved in bashing have to go somewhere, and some parts need to flex or inexpensively break to save more crucial areas breaking)
8. I've got better tyres and a stronger steering servo on order - are there any tutorials on replacing and setting up the servo?
(Pro-Line Big Joe II 2.2 and HPI Ss-40wp Servo - I think this will be useful as I'm doing a LOT of wet running and a bit of grass)
9. Are there any recommended bumpers (or other parts) to cushion landings?
Cheers
Cheers
