1/35 Orlandoo Hunter OH35P01 and OH35A01
Orlandoo Hunter
Taizhou Orlando Hunt Model Technology Co., Ltd
since 2012
OH35P01 (ford F-150 Raptor)
Vehicle Length: 170mm
Vehicle Width: 70mm
Height: 63mm
Wheelbase: 116mm
OH35A01 (Jeep Wrangler)
Vehicle Length: 126mm
Vehicle Width: 57mm
Height: 63mm
Wheelbase: 77mm
ESC
MOTOR
1. DC6V 24000RPM±5% 1:298 80RPM
2. DC6V 12000RPM±5% 1:100 120RPM
3. DC6V 15000RPM±5% 1:100 150RPM
4. DC6V 20000RPM±5% 1:100 200RPM
5. DC6V 15000RPM±5% 1:50 300RPM
DIFF
Orlandoo F150 stock gearset
crown:25t pinion:13t
Ratio 1.92:1
Orlandoo F150 V1 Brass/metal gearset
crown:20t pinion:12t
Ratio 1.67:1
Orlandoo F150 V2 umbrella Brass/metal gearset
crown:25t pinion:14t
Ratio 1.78:1
Orlandoo Jeep/Alloy diff kit
crown:16t pinion:8t
Ratio 2:1
GEARBOX
Orlandoo F150 Gearbox
pinion 19t
idler 19t
output gear 19t
Ratio 1:1
Orlando Jeep Gearbox
pinion 19t
output gear 19t
Ratio 1:1
incomplete.... need sleep check back later
since 2012
Vehicle Width: 70mm
Height: 63mm
Wheelbase: 116mm
Vehicle Width: 57mm
Height: 63mm
Wheelbase: 77mm
ESC
MOTOR
DIFF
Ratio 1.92:1
Ratio 1.67:1
Ratio 1.78:1
crown:16t pinion:8t
Ratio 2:1
GEARBOX
pinion 19t
idler 19t
output gear 19t
Ratio 1:1
pinion 19t
output gear 19t
Ratio 1:1
oh btw here are my timelapsed build video and some fun around the room
Not much flex articulation on axle when climbing over obstacles but scale enough to be 4x4 in micro world.
Btw i haven't install the rear light because its too small to solder, the front much easier because it uses standard size old type LEDs.
Videos:
Videos:
Woah! you got some serious collection of micro scale crawlers and diorama like tracks! Those six wheeler looks cool too. Sweet! I'm gonna work on my other micro this weekends and building micro tracks..
Keep it up.
Thanks mate, any questions sing out.. Im always happy to help and share my ideas.... I like to Inspire people
here man.... here is a bit more.... these are some projects im working on as scale accessories for the rc cars
Mack R 600 (possibly will be converted to RC)
Daihatsu Mira Walk through van
R33 Skyline GTR (painting soon)
MK1 Ford Escort (painting today)
These are Awesome little cars, My yellow one has been driven so much that i had to repaint it lol.... (on the sides where the kids and I pick it up form, was wearing very thin)
These are the best spring holders ive seen. I mean lets be clear, its not a shock absorber as there is no dampening, but still they are very nice...
The shaft it self it thicker than the stock unit and seems to be able to keep it self a lot more straight in the housing. The end cap is conveniently threaded for easy assembly and the shaft ends thread is recessed to give the ballend something to screw up to meaning the shocks are all the same length, no more tweaking
some other key points... the top and bottom ball ends have been redesigned with thicker ball cups and they work like a dream, they really snap onto the balls and there is little to no resistance in the ball joints... that there is a massive improvement over stock.
Verdict, very nice unit... during assembly there is some nice features that made that a lot easier but when driving there is no difference. if anything in theory u could argue its worse because the shocks are so smooth the dont act as friction shocks.
IMO this is a durability upgrade, If u are sick of your shocks poping of the balls, then these are defiantly worth a look.
if you are looking to improve performance, you will need the optional springs
Extra quick hack mods for Orlandoo Jeep and F150 have been published to improve stability and axle articulation here, now its an ultimate crawler.
Video:
After simple mods from video above the Jeep looks beautiful and stable. Axle highly articulate thanks to more clearance behind the wheel wells/fender. Notice the wheel "off-set".
Photos:
Video:
Photos:
I totally want one of these. I just don't think I would get to use it much. But, oh so cool to have in my collection! Have you tried to cram the sound module into one of these yet?
Funny u mention the sound unit. ive only just fitted on to my Orlandoo based Freightliner.
but yeah they fit in the ford, but in the jeep it really compromised on battery room.
here is some random pics from the last week of playing
