1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
help needed engine heating and smoking
Old 02-05-2020, 03:20 PM
ecx guy
Question help needed engine heating and smoking
i have a ecx ruckus and i changed the motor pinion gear and the first time i turned it on and applied power the motor wouldn't turn so i loosened the screws and applied power and the motor turned all right but it was a lot quieter than it used to be but the motor lets a bit of smoke out not much just a little i remember it did this when i first got it maybe just running the new pinion in
any advice would be much appreciated
Old 02-08-2020, 01:34 PM
Big Alice
A smoking electric motor is not a good thing. Just guessing, check the gear lash isn't too tight or maybe too tall of a pinion. You running it in grass? If the motor is smoking, don't run it till you find the problem or you'll be buying a new motor.
Old 05-24-2020, 01:48 PM
funcentric
funcentric's Avatar
If you changed the pinion gear, I'm guessing you geared up with a higher tooth and the overall diameter is larger. The motor therefore needs to be pushed further away from the spur gear than your original setup. If you didn't adjust the motor mount location, yes, the gear mesh will be much too tight. That would cause just too much friction and work the motor too hard.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
