1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
Help with signal loss
Old 03-14-2020, 03:18 PM
SKYLLZ1014
Default Help with signal loss
Hey fellas, Iím a relatively new to the RC car world but can fix anything and recently was given a used 1/18 scale ECX torment 4X4 SC truck. Yes, I know theyíre not the greatest of RCís but it was free so who am I to complain...lol...Anyhow, Iíve only used it a few times as Iíve been having issues with it constantly losing signal between car & transmitter. To my knowledge it hasnít been used all that much and the esc, motor suspension etc. are all in good condition. Anyhow, Iíve already tried all the obvious things with charged/new batteries and all that. Iím sure thereís plenty of RC masters on here so I wanted to run it by you guys and see what I should do as it would be such waste to leave it sitting there. Is it bad esc or something like that?? If anyone can at at least point me in the right direction it would be GREATLY appreciated. Thanx!
Old 04-01-2020, 11:18 AM
MrFrenz
There is a lot of probability like problem with receiver,transmitter,esc etc but could be also because of loose connection. Maybe you can try to held the car steady and check singal losing still occurs.
Old 04-01-2020, 07:41 PM
SKYLLZ1014
I found a small issue with it that I thought was going to end up being the issue causing the signal drop which was frayed wiring going into the EC3 connector coming out of ESC where the battery plugs in but I completely cut bad connector off, fixed wiring and soldered new connector on but unfortunately still having the signal drop. I actually just fixed the connector issue today, was waiting for new connector to be delivered, and ran it around for about 5-10 mins and started having issue again. Sooo after a bunch of cursing and anger since the wiring I thought was the problem actually wasnít lol, I did pick it up and ran it while holding it steady in my hand and it DID in fact drop the signal while holding it as well. I also noticed today while trying to mess around with it that the ESC status light will blink slowly as it does when itís searching for the transmitter. So now Iím not sure if the issue is with the transmitter itself or the antenna on the esc. Batteries are all brand new in controller/transmitter so itís not for lack of power. I am going to attempt to take apart the controller tonight and see if there is any loose connections inside. However I am noticing at first glance that where the switch and adjustment panel is on the top of the controller, it canít be split apart in that section without completely peeling off the false cover that goes around the buttons. So I am going to attempt to take apart the controller tonight and see if there is any loose connections inside. However I am noticing at first glance that where the switch and adjustment panel is on the top of the controller, it canít be split apart in that section without completely peeling off the false cover that goes around the buttons. So now Iím not sure how far I want to go with that since I donít want to damage it. Iíd hate to have to bring it to hobby shops for repair but Iím not sure if I have any choice at this point. Any other tips with new info I found would be greatly appreciated
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
