My scorpian has come
Hey guys
took my mini-t out for a bash yesterday and the stock motor stoped working [:@] i think it was the 8.4v packs so last night i ordered a cheap 300 motor temp untill my scorpian come
about 12 today mr postman had 3 parcels for me 1 from america so i signed for them and quickley ripped open the packs it was the cheap 300 motor and my scorpian motor and my servo so i took the old plugs of the broken motor and droped them onto the scorpian put it into my baby-T and full throtteld it om my tiled kitchen floor and it wheeled omg how fast is this baby cant wait to take it out in some wide open space
so the other 300 motor will have to be kept as a spare
i got oil shocks comming soon so it should handel a treat all i need now is my new sets of tires which will have to wait mine are ok now apart from being totaly bald[:-]
cheers to all of u for all ur help in choosing the motor especialy NYYSR cheers buddy [8D]
RE: My scorpian has come
Hi
Where did you order the parts from in the states? How long did you have to wait for delivery. I'm interested because the parts are in very short supply in the uk at the moment.
NY,
no problem glad 2 here it mate.
now heres some more good news, the stock electronics can handle the new 8 cell 9.6V bat packs made by
http://www.blindbatts.com/catalog/pr...roducts_id=148
ive been running the 8 cell bat for almost 2 weeks now with out any problems what so ever.
hey did you get the O ring kit for your losi oil shocks?
its a must so you can stop the oil weep problems with the losi shocks.
thatscool, you can get the motor from http://www.b-p-p.com/Mini-T.htm
its 25.00 with the motor mount.
cheers mate
cheers mate
im sorry mate i went against ur advice and got the gpm shocks i liked the look of them and some 1 i now has the losi's and i thought they were crap
ill let u know what they are like
im happy with my 8.4v but when needed ill upgrade to thoughs babys is the speed increased much and what are the benefits of them over the 8.4v
NY,
ORIGINAL: mad_taffy2k
but yea Project_2501s right on the money and also about 2-3 min longer run times.
Actually NYYSR with the additional 1.2 volts his runtime would decrease.
9.6 volts on a speed 300 motor especially one with the timing advanced will severely reduce the motor's lifespan. If I were you mad_taffy2k I would call it a day with 8.4 volts.
NY,
actually your wrong, i think i would know being that i have run this set up for about 2 weeks now.
but thanks again for your imput.
NY,
o realy so now 7 cell 8.4V 1100 mah bats run longer than 8 cell 9.6V 1200mah bats?
maybe you should try running this setup befor you make unknown claims.
i can feel another one of your sales pitches coming on.
I am sorry that you are uneducated in this field bro.
Compare a 7.2 KAN cell pack to an 8.4 volt KAN cell pack yes the 7.2 volt will yield slightly longer run times.
I can get rather technical and provide you a lengthy explanation but it wouldn't make sense to you anyway.
Here is a simple way to test the theory. Charge a a 7.2 volt pack that you have at 1 amp then run it. Next time charge that same pack at 2 amps and if you have a decent charger note the increased voltage level. Then go run the pack, you will see that the run time will decrease.
Like an idiot I once charged a pack of mine fully at three amps and my batteries dumped faster than you could believe (approximately four minutes).
NY,
ORIGINAL: Intelligentsia
heres an easyer test.
get both bat packs, charge them at 1-1.5 amps (like i do) and see what one runs longer.
simple if you ask me.
but then again im still using a sundial 2 tell time lol lol (only slightly kiding ) lol
I don't need to do anything because I already know the end result. I am sorry that you have previously been misinformed. Why do try to debate things which you don't have the slightest clue regarding?
Please explain to me how providing your motor more voltage would yield increased run times? I would really like to know. Especially when the increased voltage further reduces the motor's efficiency and increases both commutator and brush wear.
You know what, forget it.
Thread starter, enjoy your Scorpion but as I stated 9.6 volts will increase both your run time and reduce the overall lifespan of your motor so be careful.
NY,
heres a clue, if your going 2 get so worked up then maybe you should avoid reading my post?
the longer run time comes from the mah rating just in case you missed that.
one is a 1100 and the other is 1200 (8 cell actually charged up to 1265) but then again im sure youll argue that as well.
just for the record i do agree with you about shorter run times with increased voltage.
this i know 2 be true when i was adding more cells 2 my BL stampede ( i used matched GP3300s) and found out that thou it gave me much more power as i added cells, it would not increase the run time.
and in fact it started 2 decrease.
but in the case of these bat packs in question its not true due 2 the fact that their is also a higher mah rating.
if these sub bats were at the highest possable mah rating out their then what you said would hold true.
but when one is rated at 1100 (the best charge ive ever seen out of it was 1020-1060) and the other was a 1200 (ive seen up to 1265 on it) then you can expect 2-3 more mins run time between the 2.
also i run my bats stone dead, and before you say it YES i know its no good to run Ni-MH completely dry, but until i kill a bat cauzz of it ill keep doing it.
peace bro
Well then yes you are correct being that the cells are of varying mAh ratings... er well to a certain extent but I will not get into that.
Actually you can discharge your NiMH cells until your car stops. This will not completely discharge the cells to 0 and in turn will not harm your cells. Your cells should be conditioned fairly well because you are in essence cycling your cells.
It is the lithium cells where discharging them to that degree can become dangerous.
jesus guys. ever heard of internal impedence?
more cells = more impedence. li-polys and li-ions have extemely low internal impedence; thats why you will get a few more seconds (maybe a minute) at the same mah.
7 cells at 1200 mah will last say 20 minutes w/ x-motor (just pretend), an 8 cell 1200 mah pack with the exact same type of battery will have maybe 18-19 minutes run time because of the internal impedence. its only slightly more, but in the time that you're running you will have a lot more fun.
now, this is about fun. not not knowing what you're talking about and arguing because you dont want to be wrong. fun guys, no need to argue. it's all settled now. done, now, go race your mini's and have a blast.
NY,
yea thats usually what i do when i run my r/cs, i run them 2 a dead stop.
kinda anoying but ive always had good results from it so y change.
i was never realy found of cycling nimhs on a charger or discharge thou.
i dont undertstand why peiopel argue so muc on this whole site
i have lernt so much and i hope that io have also helped people learn from my expericances lets all get on and drive our little car's till something else breaks
When I am on these forums I like to keep things simple. Most people do not understand the more technical aspects of r/c or electrical in general.
I am an electrical engineer but granted I do not know every single detail which pertains to electrics. I am learning every day and perfecting my craft.
