1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
MAMBA Brushless Motor Thread!
Old 07-31-2004, 12:35 PM
studysession
studysession's Avatar
Default RE: MAMBA Brushless Motor Thread!
Nice and smooth - now did you encode it using Windows Movie Maker? What settings did you record at? The sound and video was nice and smooth, no delays.
The MiniT seemed to have a nice smooth hum as it passed by. nice!
Old 07-31-2004, 12:37 PM
Irlsh
Irlsh's Avatar
ye movie maker i tried to make it as small as i could without loosing to much distortion and yes i left the sound the way it was wich uses the space as well it could have been smoother but then the size would have been outragous yanno
Old 07-31-2004, 01:56 PM
travis m
nice how fast do you think that goes and can the mambas do wheeles
Old 07-31-2004, 07:13 PM
Irlsh
Irlsh's Avatar
yeah but those tires were so bald
Old 07-31-2004, 09:13 PM
micronut154
Well since I am knew to micro and this is the Mamba brushless motor thread I thought I would ask this question. I just bought a brushless motor and esc. The box says " The Mamba" and thats it. The esc is the Mamba 25 amp but that is all I know about it. The side of the box has the part # MMB25-CM2042 Performance Pkg. I was reading about 8000's and 5400's. I am asumming mine is a 2042. Is mine outdated or just lower in the line or what?
Old 07-31-2004, 09:52 PM
  #31
travis m
yours id the next step down of the 8000 your i thing is the 5400 and the sport is the 2042
Old 08-01-2004, 02:00 AM
  #32
Irlsh
Irlsh's Avatar
2042 is the lowest speed version no its not older it is just slower motor made good for track racing where top end isnt a factor and if u put a litho on there it would be better then any big block etc plus it would last alot longer with run times!
Old 08-01-2004, 02:04 AM
  #33
madblunted
madblunted's Avatar
yeah get some lipos, 3 running at least 11 volts, program your esc, and you will be plenty happy.
Old 08-01-2004, 03:45 AM
  #34
studysession
You bought the lower end one not out dated. The one you bought is 4200RPM's per volt. The 5400 is 5400RPM's per volt and the 8000 is the one that I ordered and Irish has - it is 8000 RPM's per volt.
Old 08-01-2004, 10:47 AM
  #35
madblunted
madblunted's Avatar
no.. it stands for something else, something volt, i dont think it was Kilo Volt but something else.... Kensil Volt or something.. i'll have to look it up somewhere, if it was the rpms it would be nuts!! Good theory though.
Actually I found it, you right, and I guess I am right, check it out..
Q. What are motor constants?
A. (Jim Bourke)
Motor constants are used to define the characteristics of a motor in quantifiable terms. Every motor can be accurately defined using exactly 3 motor constants: kv (rpm/volt), rm (terminal resistance), and io (no-load current). The kv constant is the rpms produced by a motor per volt applied. A 100% efficient motor could be described using this constant alone, but there are losses in the motor that make this impossible. If the kv is known, then we can determine another constant called kt. Kt is the torque produced per amp. kv and kt are proportional as shown: kt = 1355 / kv This relationship between kt and kv is a law for every motor. The rm constant is called the "terminal resistance" of the motor. This is the loss inside the motor due to the wiring in the armature. The rm constant represents a loss of power due to imperfect materials inside the motor. The final constant, io, is the no-load current. The motor table at the end of this faq shows several popular motors and their constants
I found this at http://www.ezonemag.com/pages/efaq.htm#motor5
Old 08-01-2004, 10:18 PM
  #36
Irlsh
Irlsh's Avatar
great info mad!!
Old 08-02-2004, 10:14 AM
  #37
alxrymnd914
I have stock electronics and gearing. Where can i get a mamba and what else should i get?
Old 08-02-2004, 11:16 AM
  #38
studysession
My MRS4 Kit and Mamba 8000kv motor arrived today!
Old 08-02-2004, 11:18 AM
  #39
Irlsh
Irlsh's Avatar
nice lets see some pics and maybe a video
Old 08-02-2004, 11:21 AM
  #40
studysession
It is a kit - tonight I will put together most if not all of it. Tomorrow paint the body and HOPEFULLY get to run it by then.
Old 08-02-2004, 03:35 PM
  #41
studysession
I got the chassis all together. Tomorrow I will paint a Sky Line body for it.
Old 08-03-2004, 01:41 PM
  #42
studysession
I did not want to double post, so my pics are here:
http://www.rcuniverse.com/forum/I_bo...2022375/tm.htm
I cant run it until my batteries and battery bars arrive.
Old 08-04-2004, 12:56 PM
  #43
travis m
what kind of servos and you guys running in your mini-ts
Old 08-04-2004, 12:59 PM
  #44
Irlsh
Irlsh's Avatar
most people run hitec i run bluebird have used then for awhile and got a good deal on a bunch.. use wich ever u prefer
Old 08-04-2004, 01:00 PM
  #45
studysession
I ran it with the elcheapo batteries today. This is my 1st micro and I find it will take me a lot of practice to get good at driving this thing. My 1/10 scale I can turn quick and just spin. Well this if you turn quick at high speeds it flips.[X(] Over all it is a lot of fun.
Old 08-04-2004, 01:02 PM
  #46
Irlsh
Irlsh's Avatar
im editing the video for my m18 right now keep a close eye!!!
Old 08-04-2004, 01:29 PM
  #47
Irlsh
Irlsh's Avatar
Ok follow the link to the other post with the video link!!!!
[link=http://www.rcuniverse.com/forum/Ok_here_is_my_Video_of_M18_Mamba_8000/m_2053895/tm.htm]http://www.rcuniverse.com/forum/Ok_here_is_my_Video_of_M18_Mamba_8000/m_2053895/tm.htm[/link]
Old 08-04-2004, 07:22 PM
  #48
alxrymnd914
Where can I get a cheap brushless motor that needs no modification and what else do I need?
Old 08-05-2004, 12:21 AM
  #49
travis m
is the hs55 good and does not break
Old 08-05-2004, 11:58 AM
  #50
Irlsh
Irlsh's Avatar
most dont need mods but u need a brushless esc to go with it and www.b-p-p.com has a decent selection!
