Whats a good aftermareket servo
RE: Whats a good aftermareket servo
ORIGINAL: Tigger N. Bennie
I don't know about the HiTec HS-81MG, but Losi has one for the HS-55MG. I don't even run one myself, than again I'm using a different servo.
http://www.teamlosi.com/newprod/2004...t-servosvr.htm
I use a HiTec HS-5125MG servo (programmable metal-geared airplane servo). Does it drop in? No, but I made it fit.
HS-5125MG Digital Slim Wing Servo 0.84 oz
(25.0 g) 0.51 x 1.14 x 1.18 in
(13 x 29 x 30 mm) 41.7/48.6 oz-in
(3.0/3.5 kg-cm) 0.17/0.13 sec
@ 60 deg 3 pole ferrite motor, all metal gears, dual ball bearing $65.95 sailplane aileron, flaps
Here is a HiTec link to it:
http://www.hitecrcd.com/Servos/hs5125.htm
