1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
Xmods Questions
Old 04-08-2007, 03:27 PM
  #126
VXL ENCHILADA
Default RE: Xmods Questions
Is there any way that I can buy a 25-tooth spur gear for the xmod evo car ( by-itself) because mine got stripped[&o][&o]...
Thanx
Old 04-08-2007, 09:11 PM
  #127
Dokioto
Dokioto's Avatar
You strip a spur.. That would be hard... Any way check Atomic Mods.com, they usually have all kinds of replacement parts.
Old 04-08-2007, 09:19 PM
  #128
VXL ENCHILADA
I have $36.00 to spend on xmod evo car upgrades.... I already have the suspension and steering upgrade, the tire and wheel upgrades, and the stage two motor upgrade. What upgrades should I get....
Thanx
Old 04-08-2007, 09:21 PM
  #129
Dokioto
Dokioto's Avatar
Ball bearings should of been your first upgrade.
Old 04-09-2007, 09:26 PM
  #130
fox000racer
fox000racer's Avatar
I am new to the whole xmod thing but i do have every possible upgrade for my gen.1 xmod besides the 4 wheel drive, lights, and neons. I have the stage 2 motor but would still like to have more speed and acceleration. does anyone know anything about putting a 180 motor from a stock hpi mini rs4 engine in the xmod? i was thinking about doing that but if it wouldnt fit (which i dont think it will) can you tell me what motor i can put that will fit and add alot of speed and acceleration (also i am pretty cheap lol)
Old 04-10-2007, 08:38 PM
  #131
Dokioto
Dokioto's Avatar
I run this motor with my Gen1 xmod- http://www.undergroundxmods.com/cata...afc176e1a4c43c
My xmod is all aluminum and I am using a 5 cell battery pack to run it.
Old 04-10-2007, 08:41 PM
  #132
Dokioto
Dokioto's Avatar
ORIGINAL: fox000racer
I doubt that... You may have all of the Radio Shack upgrades (most aren't worth it anyway)... But you don't have good upgrades..
Old 04-11-2007, 10:21 AM
  #133
fox000racer
thats what i meant every radio shack upgrade but can u tell me what you would call worth it that i could put on it but i do have a very low budget
Old 04-11-2007, 11:33 PM
  #134
Dokioto
Dokioto's Avatar
Well if you already have ball bearings the I would get AWD and [link=http://www.undergroundxmods.com/catalog/product_info.php?cPath=34_54&products_id=34&osCsid=87a2dc9e8d0ec72d8bafc176e1a4c43c]this[/link] motor is nice.
I'll try to get some pics of my xmod on here (my body looks very bad though).
Old 04-11-2007, 11:37 PM
  #135
Dokioto
Dokioto's Avatar
If you read that link I gave you it says that, Dyno tests have shown speeds of over 20+ MPH @ 4.8V. According to them it is the fastest motor you can stick into a stock vehicle.
Old 04-12-2007, 10:42 PM
  #136
fox000racer
do you need to change the FETs or does the motor just bolt in and go? also do you need to modify the chassis to put it in or is it the same size? and do the wires need to be sotered on?
Old 04-12-2007, 11:22 PM
  #137
Dokioto
Dokioto's Avatar
I said this is the fastest motor you can stick into a STOCK vehicle... If you looked at the link with the motor on it; it says "Fastest possible motor able to run on stock FETs.. You don't need to solder anything on.. It comes with the plug already installed. It also comes with a pinion installed if you want one (you can get an 8, 9, 10, or 11 tooth pinions).
It is a little longer though so you don't have to use the front motor mount.
So you don't have to do anything... You just install and have fun.
Old 05-04-2020, 04:34 PM
  #138
Jay54
Default Best tires for rcp track's
New too this forum i know xmods are pretty old but I'm still a huge xmods fan actually the only rcs i drive with that can someone please let me know what are the best tires too have on my gen 2 for drifting on an xmods rcp track
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
