?? on mini-T ball diffs
MO
So i just put one in (racers edge) and im wondering if i put it in backward? Is that possible. I didnt think so, but im having a hella time keeping the ball diff cranked down. Seems it always wants to loosen up on me to the point that it wont move but under the slightest trigger (other wises the diff just spins) Ive looked at it close and its NOT the slipper clutch on the drive gear. and the pinon isnt slipping.
whats the word?
whats the word?
NC
RE: ?? on mini-T ball diffs
Try turing it aroud but if that doesnt work put some thread lock on the bolt. I put a mip ball diff in my mini lst and had a problem with it loosening up. Since I put the thread lock on it, its been fine. Also with my xxx-t mf2 I have noticed that if the thrust bearing are not set right or lubed enough it will cause it to loosen(just something to think about)
