OFFICIAL Team Losi Micro-T thread !!!!!!!!!!!!!!!!!!!!!!!!!!!!
#4626
MI
RE: OFFICIAL Team Losi Micro-T thread !!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thanks for the info Tyhodge. I don't think those ball joins will screw into my aluminum parts, otherwise I'd be all over it! I broke linkage after linkage until I started using zip ties, and they work perfectly. When I build another Micro-T (my next one will be brushed) I'll make sure to use the ball joint linkage.
#4627
if you but a tap, than you can retap the holes in the aluminum to make them a tad larger. they are really close to fitting, but once in i wouldnt remove and also use loc-tite
#4628
i'm suprised someone hasn't made a one-way for these yet....that would get rid of the diff problem
#4629
Here is a solution to the diff problem - http://www.youtube.com/watch?v=DeUVdOJBW80
It's been around for quite awhile. If you do this you'll probably never have diff problems again. I don't know if there's a real shim you can buy, but this looks like it will work. I beleive the wire is a cat5 wire like you may have used for your antenna.
#4630
ORIGINAL: Metallover
here is the shim you would need:
http://www3.towerhobbies.com/cgi-bin...?&I=LXJHR8&P=0
and here is where you would put it:
http://www.postimage.org/image.php?v=Pq17xeQA
although i found it better to put it between the inside of the case and the bearing.
#4632
the 3racing gearbox alone is one major upgrade. if you want your micro to glide as smooth as butter across the floor, id get it. its really smooth, i can let off and let it just roll across the floor for about 5 feet before it stops [8D]
#4634
is there a big difference between the Integy and 3racing aluminum transmission cases? the first one i got was the integy one....looks good but for some reason has a binding problem internally (it came back after swapping diffs again)....just ordered the 3racing one...hopefully it doesn't have the same problem
#4635
integy one doesnt have bearings like the 3racing one does. which makes the integy gearbox basically an aluminum version of the stock the 3racing comes with bearings, you may need to shim it and may not. some have needed it and some havent. you wont regret the 3r one once you get it tuned right.[8D]
#4636
hey guys im get a bunch of parts for my micro t and am wondering if i should get the atomic b motor or go brushless
#4638
don't know if you guys already knew this (haven't read much of this thread yet) but the xmod evolution series truck shocks fit. Basically the xmod truck upgrade shocks fit.
#4639
ORIGINAL: tyhodge07
#4640
ORIGINAL: Hibityhupla!
sweet...thanks for the info.....they dont look much different in photo's....hard to tell
ORIGINAL: tyhodge07
#4641
ORIGINAL: huck ur rc
#4642
im planing to get either the atomic moter with 7.4v 300mah lipo or get the brushless setup with the 11.1 lipo batt p.s. i have a dt chassis to bit the lipos
#4645
i personally would only go with the bb2 and the lipo than spend the other money on a track setup. around here basements are not that large and a lipo and brushless seems like you wouldnt even be able to have enough room to fully open up and let it rip to get full speed, and only be using like half speed the whole time, but not knowing how much room you have in the basement, you may have the room to get most the use out of it, or even may not have the room and not get the full use out of it. im just a get my money's worth type of guy, and going 100+ on a bl lipo setup id want to be hitting its full potential, rather than only a certain amount than risking smoking the wall and breaking it all in half, lol
#4646
Just [link=http://www.youtube.com/watch?v=ZBFJP1pk3dk&feature=channel_page]a quick video of my micro-t[/link] I thought you guys might like. Nothing special.
#4647
Ya my basement is about 60f by 25f Im thinking that It would be good for the brushless wit lipo also dose any one know the speed the brushless will go with 11.1v lipos in it ?
