Digital Piranah & Micro-t battery
Has anybody used the digital piranah to charge the stock micro-t batt ?
Ive heard of false peaking charging at .1 amps (very low) on some chargers.
any info is appreciated !
RE: Digital Piranah & Micro-t battery
Is this the charger you guys are talking about? http://www2.towerhobbies.com/cgi-bin...&I=LXCLD5&P=RF
If so you can charge your batteries at one amp...
Yes, thats the one.
not 1 amp but .1 amp,
( if it really goes that low why shouldnt it work? ).....Because some inexpensive chargers will false peak at that low a charge rate.
low charge rates are hard to detect. Ive heard this is a good charger but I havent heard anybody use it for a micro battery.
OK, glad to hear it works, gonna go get one, didnt really want to spend too much $$.
I will read up on the manual when I get it !!!
joeyblaze , did you use the connector off the stock charger or did you go to deans ?
what mv/p do you have yours set at?
150 mah
0.2A
6MV/C
thats what i have been using with no problems and getting good run times, charge times are about 40 mins
