HOW DO YOU FEEL ABOUT MY TRACK SETUP?
My Local RC Track is between the size of a 1/10 and a 1/8 scale track, i have an RC18T Truggy Setup to race there, by race i mean for my enjoyment only, i won't be racing competitively at all. If people pass me they pass me, i'm only driving there for fun. But i still have speed to turn heads on the straight. So please all of you off road track racers let me know what you think. Let me know if this is bullet proof setup or if you have any suggestions before my season starts!
RC18T MAMBAFIED LIPO TRUGGY:
Main Chassis: GPM Aluminum
Sub Chassis: GPM Aluminum
Differential Outdrives: MIP Super Diffs
Differential Gear: 3racing 35t Aluminum
Input Gear: Stock
Spur: Aluminum 60T
Pinion: Robinson Hardend Steel 12T
Driveline protection: DP Gear cover
Steering link: DP Drag Link
Steering: Hitec HS-65MG
Steering Knuckles: Stock
Suspension Arms: AE FT Aluminum
Rear Hub Carrier: AE FT Aluminum
Battery Brace: Carbon Fiber
Shock Towers: AE FT Aluminum
Gear Box Cases: Stock
Shafts: MIP Shiny CVD Shafts
Turn Buckles: Lundsford Racing
Tires: MLST King Pin Tires
Wheels: MLST White Dish
Body: Crowd Pleazer 2.0
Gear Cover: 3racing Aluminum 60T gear cover
Motor Mount: Heatsink motor mount
Motor cooling: (2) 3racing Heat Sinks + (1) 540 sized Motor Cooling Fan
Stub Axles: Stock steel
Bearings: 3racing Complete rubber sealed ball bearing set
Motor: Mamba 8000kv
ESC: Mamba 25A + Castle Link
Battery: Max Amps 1550HV 11.1v 3s Lipo 31A continous discharge
Lipo Balancer: Apache SM-505 Smart Balancer
Bumper: RPM Wide Front Bumper
Rear Pivot Block: Integy Alloy
Servo Mount: 3racing Aluminum
Receiver: Hitec 3 channel
Remote: Hitec 3channel Agressor
Servo Saver: Hitec Servo Saver
Charger: Pro Peak Quattro 1-4C AC Charger
Wing Mount: AE RC18B
Wing: Vendetta ST Wing
Wheelie Bar: Hot Racing Aluminum wheelie bar SHOULD I USE A WHEELIE BAR ON THE TRACK????
Ball Stud: AE FT
Screw Kit: Stock
Shock Dampers: 3 racing aluminum threaded Shock Dampers
IS THAT BULLET PROOF OR WHAT? COMMENTS AND SUGGESTIONS MORE THAN WELCOME!!
Input Gear: Stock
Spur: Aluminum 60T
Motor: Mamba 8000kv
Ball Stud: AE FT
Screw Kit: Stock
NY
RE: HOW DO YOU FEEL ABOUT MY TRACK SETUP?
Get rid of all metal-to-metal gear contacts, take wheelie bar off to save weight, learn how to drive, oh...and get binoculars-how are you going to see this thing racing around with a lipo on a track like that....Is HUGE
I might buy that body for 20 bucks if you want
ORIGINAL: Mz
lose the integy and the wheelie bar
What integy parts were you reffering to?
Thanks i really like how this crowd pleazer turned out,
That is the Revellation Race Way track in Ontario, CA
Have you driven the car yet. I think you may be geared to low.
I copied a track layout from there once.
HEHE, similar to this. Is it still the current layout?
No i haven't driven the car yet, as far as with all the hop ups. but i do run a stock rc18t with mamba 8000k, 12t-60 gearing, VMX reedy IB1400 pack, and i do pretty fine on road. what do you mean too low? what do you recommend
My Feedback: (-1)
If I were you, I'd change the aluminum a-arms you have installed to the newly released RPM a-arms. They are going to be stronger, since they are RPM, and they put less stress on all other components, as well as being lighter.
The integy he was talking about was your rear hubs, but since those are hubs, I doubt even Integy can screw that up.
ORIGINAL: MBX5T Maniac
ORIGINAL: HPIownage
Yea i use to run stock gearing and i used 1/10 tc tires and moved to 12t;60t recently and noticed that i lost alot of torque, like it takes a while to get to my top speed. and i guess for the track i will never have to hit top speed maybe i should gear down to like 14t make more sense that i should have more torque and thrust off the line. thanks for the suggestion i guess i never thought about that yet. 14t here i come!
My Feedback: (-1)
HPI, the thing is, is in a brutal crash, those hingepins will bend because of the aluminum a-arms, which give no flex. I'd recommend selling those a-arms while they are new, because they retain much more value brand new, than they do when used.
ORIGINAL: Racing T
what an awesome track! how much does they charge to practice there? do you know?
ORIGINAL: HPIownage
Putting a 14t pinion would be gearing it up and that's what you should do for the stock tires since they are so small. Don't put a 14t pinion on if you are going to use 1/10 tires.
ORIGINAL: Gex_61
Well I didn't know you were using 1/10 tires. You should have 12t-60t gearing for that. That's about as geared down as you can make it and you need it for a tire with a big diameter.
ORIGINAL: HPIownage
If anyone wants these, They are for sale
http://cgi.ebay.com/ws/eBayISAPI.dll...6529&rd=1&rd=1
MODS[sm=what_smile.gif]: Please don't take off this link, give me a break. Help me out and leave it on for once, pretty pleaseeee
ORIGINAL: HPIownage
So Should i stay with the 12t;60t gearing for the MLST tires?
No worries, try it out when you have all the parts.
they actually are heavier, 1 set of 4 would weigh the same as about i know it seems bad but 3 or 4 complete sets of 4 of the stock tires. but no where near the weight of aluminum rims. they are about a half inch taller when the stock and mlst tire is compared side by side. i noticed you always recommend 55t spurs? why? i run 60's and like the speed gain
I would add the new RPM arms for the 18t. Then it will be really strong and hold up to those jumps well. Other than that it's an awesome ride, and a very nice body.
xXMAGIKXx
xXMAGIKXx
