Mini Baja, low battery power question.
NY
Hello everyone, first post here at RCU (been a long time lurker)... I have a Mini Baja that I bought used. It has the typical servo twitch and beeping, but I was wondering if it's a common thing for the motor to not respond if the battery is low? Once the battery starts to die, the motor doesn't always respond to the throttle. The Steering servo will work fine, but the motor goes nowhere. If I throw in a fresh pack, it's fine. Also is it normal for there to be lag when I pull the trigger to go forward(maybe 1-2 seconds)? The entire setup is stock, I think I may do some upgrading soon.... Thanks.
PS: I did do a search first, but couldn't really find a answer (could be my lack of search finesse)
