FOR ALL the mambafied 18t's etc........
IL
IL
RE: FOR ALL the mambafied 18t's etc........
nope no steel here....I used carbon fiber rod and tie rod eylets and ball cups....and the wheels are air plan wheels......they are made of aluminum and rubber. i drilled them out and screwed them into a brass square with some antena tubing acting as a nut for both.
PA
i too have an 8000 kv with a 3s lipo and this wheelie bar looks like it is just what the Dr ordered. good work !!!!
IL
Hey mikemcnair thanks alot for making it bigger.....Yeah it is i was tired of it flipping backwards and messing up the newly painted bodies.....so i will let you all kno how it holds up and if it does its job.
Really? I'd think with the 4WD and the 50:50 front to rear power split the front tires would bite enough to keep it down.
Guess not.
Guess not.
