mini t !!
mini t !!
hey guys, well my birthday is comming up, so im finally getting a new mini, and i decided i´d like to get a mini t, but the pro version, so this is what im getting
-mini t pro
-mamba 6800
-7 cell batts from cheap battery packs.
-i´ll use an old radio.
-could you please give a link to a good servo, if i could have the link in killerhobbies, i would really apreciate it.
what else should i get, thanks in advance.
-mini t pro
-mamba 6800
CA
FL
RE: mini t !!
some of the jrs are nice but id go with hs prolly heres a link go to the bottom theres the jrs there
https://killerhobbies.storesecured.c...ervos/list.htm
CA
RE: mini t !!
Are you sure? Killerhobbies says this:
Size .9"x .5"x .9" 24 x 12 x 24mm -65mg
9"x .5"x .9" 23 x 12 x 24mm -55
Does the 1mm make that much of a difference?
RE: mini t !!
I recommend this servo-
http://www.killerhobbies.com/items/s...1mg-detail.htm
Also, the hs65mg will fit, but there is no servo saver made for a mini-t. I stripped the gears on one of mine by not useing a servo saver. Don't do it.
