is there any minis/micros that use 4mm bearings
i need bearings with a 4mm diameter for a non r/c thing and was wondering where i could get one or if theres a mini or micro that uses bearings of this size
RE: is there any minis/micros that use 4mm bearings
im not 100% positive, but i think the bearing you get in the 10 pack of wheel bearings for the micro t's, i think the 2 larger ones might be 4mm's if not their pretty close. would any inner diameter matter? or you looking for 4mm's inner or outer?
