1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
OFFICIAL CEN MG16 THREAD
Old 01-25-2011, 10:40 AM
  #276
FUS
Default RE: OFFICIAL CEN MG16 THREAD
I was thinking to get the aluminum upgrade that cen have for the shocks, do you think this is a good buy or will be better to get a new whole set and replace the stock ones?
Old 03-27-2011, 07:26 PM
  #277
eddyeddy
Anyone got a good choice to replace the stock engine?
Now that parts are getting harder to find like piston/sleeve, rod and bearings.
Old 03-28-2011, 03:55 AM
  #278
muck76
muck76's Avatar
i was going to use an OS 18 with a short shaft crank. Then you would only need the clutch adapter CEN offers.
Otherwise use the 3.0 from CEN?
Old 03-28-2011, 04:09 AM
  #279
Ruger-777
The OS 18 might be a bit much for this truck IMO, I put one in my mt2 and it chewed up diffs like crazy. and the MG16 dont really have the strongest drive line to begin with. but if you could find a stronger center dog bone and better diffs that thing woul be a insane little ball of fury
Old 06-09-2011, 12:54 PM
  #280
eddyeddy
New Body for my MG-16. BMW Mini
ID:	1621220   Click image for larger version
Old 03-04-2012, 08:16 AM
  #281
Billsky
My Feedback: (37)
Billsky's Avatar
So what exact crank would you need to fit the OS 18 in this truck? The standard crank with the CEN MG095 adapter or the shorter one? I have seen different opinions on which OS 18 engine. I just ordered one of these trucks and of course interested in upgrading the engine even before receiving it. Check this engine upgrade out!!! http://www.youtube.com/watch?v=ocoDnsQVpFI
This is the one I remember being posted somewhere. http://www3.towerhobbies.com/cgi-bin...?&I=LXGGP6&P=7 . Thanks in advance.
Old 08-20-2012, 09:52 PM
  #282
jimel77
Hi, first post and its in an oooold thread sry about that but i found my MG16 for some days ago and now im interested in convert it to electric,looked ata clip on youtube and liked it alot
Can you help me?I dont know mutch about these things sois it possible? will it get expensive? and what do i need?
Doesent need to be the fastest car or anything, china parts will do to keep the costs down.
Best regards /Jimel
EDIT:will this work? http://www.focalprice.com/YOA95X/Hob...ersion_20.html
Old 08-21-2012, 03:47 AM
  #283
muck76
muck76's Avatar
ORIGINAL: jimel77
Hi, first post and its in an oooold thread sry about that but i found my MG16 for some days ago and now im interested in convert it to electric, looked at a clip on youtube and liked it alot
Can you help me? I dont know mutch about these things so is it possible? will it get expensive? and what do i need?
Best regards / Jimel
EDIT: will this work? http://www.focalprice.com/YOA95X/Hob...ersion_20.html
It would be best if you can find a ME16 or order the chassis and parts that are different between the two MG and Me. I think it would be a little difficult to mount a lipo on the nitro chassis. I maybe wrong, i am going off memory of when i had my MG. My ME i ran a castle 4600 and a VXL 3500 on it with 2s 4000mah 20c. There are more lipos out there now so your options maybe better.
This EZRun bl looks about the correct KV for this size of a truck.
Good luck
Old 08-21-2012, 03:53 AM
  #284
jimel77
Thank you so mutch for answering, ok will look up the parts that are different and have a look at the MG chassie and try to find out if i need something from the ME, too bad i suck at evrything about this but il have to learn step by step.
The motor wont be too weak? i have no idea
Old 08-21-2012, 04:01 AM
  #285
muck76
muck76's Avatar
ORIGINAL: jimel77
depends on what your going to power it with. If it is a finned sided BL motor it is actually a smaller can motor than the smooth sided motors. If you can find something 60 amp to 80 amp with a smooth sided can with a KV from 3500 to the 4300 you should be fine. I have not used the finned motors before and read in multiple places the can sizes. Because it is a smaller lighter truck you maybe able to get a way with the smaller can. I personally like a little bigger so i don't have to worry about heat.
There is an ME thread i was a part of years ago if you search it. It will have much usefull info on BLs in this platform.
AS far as the conversion, i think just the chassis, radio box, center shaft, body, and motor mount were different... i think...
here are two threads. I have a few vids of these also on YT.
http://www.rcuniverse.com/forum/m_85...tm.htm#8595760
http://www.rcuniverse.com/forum/m_72...tm.htm#7288770
Old 08-21-2012, 05:33 AM
  #286
jimel77
What about this? http://www.ebay.com/itm/HOBBYWING-EZ...item1e712b755f
Old 08-29-2013, 12:10 AM
  #287
jimel77
Talking
OK so about a year later I am sort of finished, it works but i need to work on battery placement.
Maybe no one is interested but just wanted to show that i really went throu with the project.
PICS!!
Teardown
Some parts
Building
Action pic (sorry for rotation)
EDIT: Video
http://youtu.be/0-SYT4PHtQ4
ID:	1914411   Click image for larger version
Name:	Photo 2012-08-22 18 50 44.jpg
ID:	1914412   Click image for larger version
Name:	Photo 2012-09-03 19 08 53.jpg
ID:	1914413   Click image for larger version
Name:	Photo 2012-09-12 16 41 07.jpg
ID:	1914414   Click image for larger version
Name:	Photo 2012-09-25 18 06 30.jpg
ID:	1914415   Click image for larger version
Name:	Photo 2013-07-18 17 44 43.jpg
ID:	1914416   Click image for larger version
Name:	Photo 2013-07-18 17 50 50.jpg
ID:	1914417   Click image for larger version
Name:	Photo 2013-07-19 11 22 27.jpg
Name:	Photo 2013-07-19 11 22 41.jpg
ID:	1914420   Click image for larger version
Name:	Photo 2013-07-30 09 24 26.jpg
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
