OFFICIAL CEN MG16 THREAD
MI
RE: OFFICIAL CEN MG16 THREAD
sorry i did not get the pics on as fast as i wanted. Life happens.
Here are 2 pics. I used the Trinity Next wing and mount and made my own mounting plate from alum scrap i had. You can get alum plate in strips at your local hardware store. I believe i saw some at home depot.
Now i did this for cosmetic use only. I do not know how much hard bashing it will take.
You can all ways try to get a bolt on plastic wing like the stock Jato uses. That would be my next attempt.
Muck, I see this beauty is on ebay right now for the low reserve of $140, someone is going to get a great deal for all of the time and mods you put into that thing. I just hope this isn't an indicator of whats to come with me and my mg16, cuz im just startin to like it .
MI
ORIGINAL: Db77
If it does not sell i am going to part out the project and do this one instead... If it does i will get another later just to try those items LOL
thanks for the kind words BTW.....
MI
wanted to let you all know that the new Mg16TC has longer body post from what i can see in this pic. I tried a Trinity Next body and the posts were too short to match up. Had i had longer post i think it would have fit. If you try this just make sure you get the unpainted uncut body.
Post pic:
Post pic:
MI
ORIGINAL: Db77
#32
The temps on the muffler are much higher than on the spark plug. Is it ok?
I'm using a duratrax temp gauge. While the temp on the plug reads 200F I get around 250F on the muffler. This plus the fact it leaks a lot.
#33
MI
at the glow plug is where you want to take the temp at. Your pipe may be hotter, i never tested mine there. I can later once it quits raining and snowing.....
Mine averages 220 and i use the duratrax gun also.
RTV your exhaust cap, it will stop the leaks. I must have been one of the few, mine never leaked. When i did the dual outlet mod, i silicone then.
240 is max.
240 is max.
#34
MI
So i am thinking of converting my Mg to a ME and going brushless. I see only 10 items that have to be done to do it. They share the same diff assemblies including arms and bulkhead components... I have a list if any one is interested....
#35
I bought a MG16 on ebay last week new for 120. A steal!. I just got it yesterday and broke it in today and all I can say is HOLY CRAP this thing is fast. Cant keep the front end down even while moving just hit the throttle and it comes up. First off I changed teh shock oil because it was way too stiff from the factory. I went over everything on the truck. I installed a roto start also. Makes starting hastle free. The only thing is the steering servo is slow and none of the wheels are equipped with bearings. Everything has bushings so I will be converting everything to bearings. Other than that its a friggin rocket. A wheelie bar is manditory.
#36
ORIGINAL: twomanytoys
Where did you find the roto start for it?
#37
MI
the servo is actually pretty good, i found that the ball cups where all the steering linkages connect were tight from being new. Now that it is loosened up some it is better.
#40
Here is a better pic. These are just tires and wheels that I had lying around for a long time. They are offset wheels so it gives the truck almost 1" wider stance.
#41
#44
mindtrix, i said unless you where using it....
If you where give the opportinity, would you also get the ME16?
Does anyone else have more info on the ME16? im looking at getting it!
I dont leave fuel in the tank. It was just a pic before i was going to run it with the new tires and wheels. Man this truck is quick!
#46
Hi guys,i've had my second MG16 for a little while now and after doing the mods that Muck76 did to he's,except the exhaust,it is a little cracker.I really love these little trucks and is the one I use most at the minute.My wife and I are quite regularly battling it out as the one I bought initially she has and also loves it but now she wants hers modding like mine so I have to do it again.Great.... I've also fitted a Hobao Hyper 7 pullstart handle and fittings to the standard pullstarter as it does'nt cause me blisters,here's a few pics of the little ripper with the mods and a few of the 5 cell 1100mah AAA pack that I made,the pack cost me 6 UK pound to make,using this method to make the pack was the easier one ,all that was needed was to cut out the original AA guide rails out of the tray and the tray then fits back in as standard and sits flush as it should,I also fitted a charge lead also.The next things I want are some wheels and tyres like some of you guys have,maybe off a Thunder Tiger SSK...
#47
MI
ORIGINAL: nitro _ burner
i think i would miss the nitro of these so i imagine i would pick up another MG16 later.... maybe MG10 this time....
#48
MI
ORIGINAL: Mr Terminator
Also for rims, TRaxxas nitro rear 2.2 1/10 scale and hpi nitro rear rims fit. The HPI have a wider off set, traxxas are the same as stock. I have not tried the 2.8 rims yet... key word yet...
#49
MI
I also wanted to let you all know CEN offers this engine with a slide carb [link=http://www.cenracingdirect.com/index.asp?PageAction=VIEWPROD&ProdID=1309]nx18[/link] as a hop up. It shows it with a rotory carb on it. i called and asked CEN if they offer a slide carb version. CS told me to just put in the comments section to build this one with a slide carb. Personally i would call to make sure it goes threw ok. I was also told there was no extra charge for the carb or swapping it.
So BL or .18... too many choices!
#50
Mr T how many runs do you get out of the rechargeable AAAs? I get a real long time out of the 2/3A cell pack i made but your AAA set up would be nicer as the bottom plate would fit better.
