roll cage / tek18
OR
roll cage / tek18
has anybody put a roll cage on there tek18? do the rc18 ones fit?
i was thinking about just useing a roll cage instead of a body i think that there would be less drag on the body that way and the electronics would be protected better. My setup is neu 1105 /3s lipo/mamba max
RE: roll cage / tek18
I guess you could...
But before buying one, you should also consider the extra weight a roll cage would add vs a lexan body, and the high center of gravity it causes. I wouldn't use one if you plan to race your tek18.
