1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
Stock RC18R radio bad range with mamba?
Old 04-19-2009, 11:53 AM
deanR
Default Stock RC18R radio bad range with mamba?
hey guys,
I have my 18r set up with a mamba micro pro w/the 8000 motor. its really fast, but my radio range has been terrible. It goes maybe 20 feet before it starts picking up signals and going in different directions. I am just wondering, is there any way I can get better range out of the stock radio? Or is it just crap? it worked ok when it was stock.
Dean
Old 04-19-2009, 12:02 PM
HJJFFFAA
HJJFFFAA's Avatar
Default RE: Stock RC18R radio bad range with mamba?
what are you using for the battery?
Old 04-19-2009, 10:07 PM
sonicj
sonicj's Avatar
try braiding the 3 wires from the esc and motor. then twist the battery wires from the battery and the esc inputs leads so that when they are plugged in they stay twisted (if you do it wrong, as soon as you let go they will untwist)
braiding the esc & motor wires is the most effective of the two. you see this done often in car & home audio to keep rf noise out of signal carrying interconnects. this is the same principle, but in reverse. you are trying to keep interference from escaping the wires and disturbing your radio equipment.
keep all other wiring (servo, battery, esc, motor) as far away from your rx and antenna as possible.
lemme know if you try it!
Old 04-19-2009, 10:08 PM
Beomagi
Beomagi's Avatar
Was it that way before you mambafied it? Check your wiring. depending on how jumbled your wires are,the mambamay interfere.
Old 04-20-2009, 06:09 PM
deanR
I am using a 2s 2100 lipo. I put RF filters on the wires and it helped but it made my mamba glitch more. so I took off the throttle one and it works ok for now. still not good range, but good enough for the racing I was doing. I will try twisting the wires.
Dean
Old 04-21-2009, 10:40 PM
peelin_out
yes, braid the three leads from the esc to the motor!
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
