Losi Mini Late Model questions
NC
hey guys, im new to the whole electric/ mini scene. my buddy built a fairly small track in his garage it's really smooth concrete. what would you guy's suggest for tires and chassis setup? id like to get pre mounts if possible.
And also what is the biggest battery i can fit in this thing? ive seen some 1500-1600mah just wondering if there is a bigger Mah that will still fit in the stock location.
RE: Losi Mini Late Model questions
It uses the 2/3A packs like a 1/18 scale car. As far as nimhs go 1600 is the highest Ive seen. You can fit larger mah Lipos though I'm sure. The stock wheels/tires should do fairly well on concrete. I think Losi sells asphalt tires for them.
I've got a Mini LST2 and for smooth concrete like in a garage floor, give these a try:
http://www.thetoyz.com/cart/thetoyz_...ame=MINI%20LST
They're not pre-mounted, but the're pretty easy to mount, just get some inexpensive wheels like:
http://www.thetoyz.com/cart/thetoyz_...%20&%20LST%202
