Do u use heat sink in ur brushless motor?
ON, CANADA
Guys,
Do u use heat sink on ur Losi Mini T or DT brushless motor? As there is a motor guard so the heatsink doesn't fit or the guard has to be removed if heat sink has to be on. What u do?
AZ
RE: Do u use heat sink in ur brushless motor?
I don't have a MT or MDT, but I have seen photos of others using these "all-in-one"
http://www.thetoyz.com/cart/thetoyz_...9465&cat_name=
http://www.thetoyz.com/cart/thetoyz_...9689&cat_name=
However, if I did own a MT or MDT I would prefer keeping the guard on rather than the heatsink because usually the guard material is thicker and tougher compare to that of those Alu heatsink. If something scratch during a wheelie, I would not want to see my BL motor working as the skid plate.
MD
your motor guard is a heat sink in itself. and i personally have never used 1 in a mini t . that's just my opinion im sure you will get some good reasons why guys do use heat sinks . i could see running a fan on your motor if its a higher kv like an 8000 or above
ON, CANADA
ORIGINAL: Mousesi2k
Use a motor guard / heatsink like me!
