1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
will a mini slash body fit?
Old 05-26-2010, 04:34 PM
nitrosportsandrunner
nitrosportsandrunner's Avatar
Default will a mini slash body fit?
anyone know if a mini slash body can fit on a losi mini desert truck without major modifications? i dont mind modifying the body mounts, but the wheels need to line up with the wheel wells of the body and fit inside the bodies width.
i would love a mini slash, but dont have the money. and my mini desert truck is already brushless!
Old 05-26-2010, 05:07 PM
t9dragon
Default RE: will a mini slash body fit?
From looking at the specs shown below I don't think the Mini Slash body will fit the Mini Desert truck... But then again you never know.....
Here are the specs on the Mini Slash
Length 14 inches (356mm)
Front Track 7.3 inches (185mm)
Rear Track 7.3 inches (185mm)
Weight 35oz (1000g)
Height (overall) 4.92 inches (125mm)
Wheelbase 8.1 inches (206mm)
Front Shock Length 48mm
Rear Shock Length 48mm
Front Tires (pre-glued) Slash All-Terrain 1.6"
Rear Tires (pre-glued) Slash All-Terrain 1.6"
Front Wheels Dual-bead 35/47mm,
12mm hex hub
Rear Wheels Dual-bead 35/47mm,
12mm hex hub
Electronic Speed Control Waterproof Velineon®
VXL-3m ESC
Motor (electric) Velineon® 380 Brushless
Transmission Heavy-Duty with Steel Idler Gear
Gear Ratio (internal) 5.04:1, (reversed input: 9.72:1)
Overall Drive Ratio 7.32:1 (stock, out-of-box)
Differential Type Hardened Steel Bevel, Sealed
Gear Pitch 48-Pitch
Chassis Structure/Material Molded Composite Nylon Monocoque
Brake Type Electronic
Drive System Shaft-Driven 4WD
Steering Bellcrank
Radio System Traxxas TQ (2-Channel)
Top Speed 30+mph
(50+mph with dual batteries)*
Skill Level 2
Required Batteries 8 "AA" (transmitter)
(vehicle includes 6-cell NiMh & charger)
Here are the specs on the Mini Desert Truck
Length:9.875 in (250.83mm)
Width:7 in (177.8mm)
Wheelbase:6.44 in (163.58mm)
Weight:1.26 lb (571g)
Chassis:Molded Composite
Suspension:4-Wheel Independent
Drivetrain:2WD with Gear Differential and Slipper Clutch
Tire Type:All-Terrain Truck
Motor or Engine:Mini-280 Electric
Speed Control:Losi MRX-R14 with Forward and Reverse
Radio:Losi 27MHz AM System
Servos:3-Wire Digital
Batteries:7.2V (4 x 2) Battery Pack (vehicle) and 8 AA Dry Cells (transmitter)
Charger:AC Wall Charger Included
Shock Type:Composite coil-over, oil-filled
Body:Custom Painted and Stickered (available in Red, Blue or Green)
Ball Bearings:Complete Transmission
