1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
Brushless esc motor questions
Old 07-09-2010, 10:47 PM
RRHobbyDepot
Default Brushless esc motor questions
I have installed a Megatech brushless system on my Pro pulse. The megatech motor is 6600kv. Can I use the ezrun 7800kv motor with the esc or do I need a new esc?Here are the specs on the esc:Brushless ESC
Current - 20 Amps continuous, 30 Amps surge
ESC Size - 44 x 25.5 x 17mm
ESC Weight - 34g
Brake - Proportional
Reversible - Yes, with lockout
Low Voltage Cut-off Programmable
The ezrun escs are 18a or 25A on the same 12T brushless motor.
Old 07-09-2010, 10:48 PM
madmax22
madmax22's Avatar
Default RE: Brushless esc motor questions
yes you can.
Old 07-09-2010, 10:56 PM
RRHobbyDepot
Is there a limit? I'm seeing 9500kv motors for the same price. can this be controlled easily?
Old 07-10-2010, 10:54 AM
madmax22
madmax22's Avatar
no limit. 9500kv is a lot of KV, heat may be an issue specially if its offroad, and you cant run a 3S lipo with it.
