Brushless Xmod Evo (Mamba) Project
15 Attachment(s)
this is my project for the summer. a Castle Creations Mamba 6800kV powered 2nd Gen Xmod. this motor was just sitting around in my room gethering dust so i decided to make something.</p> this pic is of the mount that would house the motor: This was where i had to trim plastic away from the mount so the motor would rest level to the chassis. Attachment 2237254</p> the mount again, side view: Attachment 2237255</p> This is the mount with differential and spur gear with rear suspension mounts: Attachment 2237256</p> again with motor spacer: Attachment 2237257</p> motor at rest in mount without strap: Attachment 2237258</p> again with gears meshing: Attachment 2237259</p> Motor in mount with strap: this part was tricky, trying to get the strap to fit around the motor i ended up using some longer screws and having a space between the strap and the chassis: Attachment 2237260</p> again front view: Attachment 2237261</p> next was the most difficult along with the bugs with servo centering. i had to convert a 5-wire servo into a 3-wire plug. this was done using an airplane servo: Attachment 2237262</p> i took it apart and looked at the circut board. it converted 5 wires to 3 so i unsoldered the 5 wires from the pot and the motor inside the servo: Attachment 2237263</p> i slipped the board down inbetween the slot where the AWD Drive shaft would normally sit and soldered the wires according: Servo Board Stock Servo black white white orange red black</p> Motor Stock Servo Motor black red white black</p> Attachment 2237264</p> Here is the whole car minus the esc and battery wired: i had a problem with the tires rubbing on the bottom of the motor, this was solved by longer screws and the hardest type of truck springs i could find. Attachment 2237265</p> whole car not wired: Attachment 2237266</p> car completed (messy): Attachment 2237267</p> heres a vid of the tire shredding apart: http://www.youtube.com/watch?v=2szRNs1vRdg</p> can anyone help me with the issue of the servo not centering? the servo was a Tactic nano from a cessna. http://www.youtube.com/watch?v=H_AqB00LNDM</p> smokin the tires: http://www.youtube.com/watch?v=Mil3BfUbkQw</p> im also trying to find a way to use the stock wire antenna instead of using the soft wire that comes on the receiver.</p> i may have found a way for the steering to center. using the pot from the tactic servo i used. i drilled out the sway arm from the old pot to fit the shaft on the new pot, i had to trim the shaft down about quarter inch to make it fit.</p> IT RUNS COMPLETELY PERFECTLY!!! HOLY **** I GOT THE STEERING TO CENTER!! YESSSSSS!!!!!! http://www.youtube.com/watch?v=_aO8q770CoM</p> i now own possibly the fastest xmod ever.</p> heres a pic of the car with my Saleen body: Attachment 2237268</p> The 1st test (ever) will be a speed test on 4 Energizer Ultimate Lithium cells. (9 effing bucks for 1 pack Dx) theyve shown a significant boost in power and speed vs alkalines. The body will be ON to help with aerodynamics and reduce drag. I have never driven this car outside because i dont live on a smooth road. So ill head out to the tennis courts soon.</p> |
RE: Brushless Xmod Evo (Mamba) Project
the little losi motor for the micro t would be better
Very cool
mega power in that little sucker.
nooooooooo it would be pathetic in power and speed compared to this! xD GOBIGORGOHOME
ORIGINAL: fasterrcs the little losi motor for the micro t would be better |
ORIGINAL: redfisher1974 mega power in that little sucker. |
How are the gears holding up?
ORIGINAL: redfisher1974 How are the gears holding up? |
