Which RC18T Motor?
Which micro motor is better for on-road carpet track racing? I am going to put it in the RC18T!
United RC K3==[link=http://www.unitedrc.com/store/product.asp?ID=28]K3 Link[/link] Fantom Mini-Mod== Go to www.fantomracing.com click products-then go to electric motors-then hit micro modified motors and mini-mod will come up!! Any other motor suggestions would be greatly appreciated! I would like alot of top-end for racing!! Enough bottom end for mini jumps and good starts though! Drew Which one and why? |
RE: Which RC18T Motor?
As i said before.
Get Radishacks Pro RK370 motor (on $bay). It's tuned properly to maximize the power bandwidth. K3's are tuned for high rpms only. Its the best bang for your buck. [8D] |
I cant find it on ebay!!
drew |
i think there are to many threads pertaining to this exact issue. someone close these please its annoying that the first page is very cluttered as it is..
For the RC18T, doesn't the Krystal-3 motor need a big block motor adapter?
I would pick the mamba 6800 for the rc18t
if your putting the k3 in a rc18t no u do not need a motor plate if your putting it in the minit u can get one or just open the slider hole a lil bit. if putting in a m18 yes u need a motor plate,.
i would go with the pro rk370 v2 these are ausome motors i had a v1 in my 18t ind it flew[&:]
i burned up to rk370 from daniel not to mention i know him from other boards etc... i just have to recommend something based on my experience. i have the k3 and in my opinion the URC k-3 is quiker then either of the pro rk370 motors i had. i used to tell people to get the rk370 till i burned up both with the same setup as i use on with my k3 wich is a novak XRS esc and a 6 cell gp1100 i have run my rc18t so many times with my k3 and have never had a problem yet.
