RCU Forums
-   1/16th, 1/18th, Mini & Micro RC Cars (https://www.rcuniverse.com/forum/1-16th-1-18th-mini-micro-rc-cars-235/)
-   -   Tamiya MAx Climber TLT - help needed (https://www.rcuniverse.com/forum/1-16th-1-18th-mini-micro-rc-cars-235/4601163-tamiya-max-climber-tlt-help-needed.html)
izzy 08-09-2006 07:58 AM
I am about to purchase this kit
can any one shed some light on what is needed
especially what is a good ESC with reverse
what motor is recomended ( 1 for speed and 2 for crawling )
what else is needed to complete this
thanks
Izzy
Mattdg67 08-09-2006 08:25 AM
RE: Tamiya MAx Climber TLT - help needed
Go in the crawler forum on here youll get more info [I could help but I am not good at helping people]
Seek and Destroy 08-09-2006 08:34 AM
ORIGINAL: izzy
thanks
Izzy
For an esc I would get a Novak xrs.
A motor for speed, depends, A 15 turn 540 can is your limit with that esc. But for crawling, a 55 or 65 turn motor will work great. I'll make a list thing of what al is needed.
Motor: 15 turn limit for speed, 55-65 turn for crawling
Esc: Novak Xrs, 15 turn liit with a 540 can
Battery:If it is the max climber version, then a stick pack will work. If you had 4200 mah bats in there and 55-65 turn motor, you could get atleast an hour of run time.
servo 1:Just any full size servo, probably something from hitec would be good
Servo 2:Same servo just in the back. You don't need the servo in the back but it helps you crawl a lot.
Reciever:Any 2-3 channel reciever.(3 channel if you use the servo in the back).
Radio:ANy 2-3 channel radio.(3 channel if you use the one in the back).
