Mamba help
Ok.. I have a Mamba 25 esc.. I try to caliberate it with my jr xr2 radio and reciever and it reconizes full throttle but not braking.. If i use any other transmitter and reciever it will work fine.. How come it won't work with my jr? batterys? Thanks in advance
RE: Mamba help
Make sure all your batteries are chargered and follow the directions carefully.
RE: Mamba help
Are you waiting long enough for it to be ready to see the brake travel?
RE: Mamba help
They are all charged and ive following them like to the dime... it just wont' work with this reciever and transmitter if i do it with my other transmitters it will work....and dasmopar all I have to say to that is no comment
RE: Mamba help
Everything else works except reverse, right?
RE: Mamba help
Ya when i go to caliberate it wont reconize reverse and no it isn't on the setting for no reverse
RE: Mamba help
Ok.. I figured it out..Its going into programming mode and it has already been caliberated but caliberated wrong.. So now im trying to recaliberate and it won't let me.. like if i swtich transmitters and go back to the jr it saves the settings.. how do i recalibarate it ?
RE: Mamba help
follow the directions!
it tells you how to go into programming mode i dont understand why there are so many threads with mamba help its in the directions!!!! |
RE: Mamba help
Ok if you even read my post i wasn't asking how to go into programming mode so ya... I was asking how to recaliberate a controller that already was caliberated...and just switching to a different controller doesn't work.. it will like rememeber that i already caliberated the controller
RE: Mamba help
I agree..... I followed the directions on a dime also, but it didnt work. I got the usb cable and didnt even program it to my remote, i just plugged it in and it worked with out programming it with a tx.
RE: Mamba help
Ya I have the cable but it can't caliberate a radio..[:@]
RE: Mamba help
How do you recaliberate the radio for a mamba???....HELP PLEASE
RE: Mamba help
ORIGINAL: flyingjato3.3 Ok if you even read my post i wasn't asking how to go into programming mode so ya... I was asking how to recaliberate a controller that already was caliberated...and just switching to a different controller doesn't work.. it will like rememeber that i already caliberated the controller it tells you how to go INTO calibrateing mode! are all your trims set to zero,and whats the brake set at on your controller... |
RE: Mamba help
do as follows:
Disconnect battery turn mamba switch off connect battery mamba will flash all colors apply full throttle turn switch on wait 2 seconds mamba flashes green and rings 4 times indicating throttle measured mamba flashes red while beeping push full brake wait 1 second mamba flashes red and rings 4 times indicating brake measured mamba flashes yellow while beeping put trigger to neutral wait 1 second mamba flashes yellow indicating neutral measured wait 1 second mamba will flash all colors and ring once do those and try it again... |
RE: Mamba help
omg it dont' reconizge when i put full brake....lol
RE: Mamba help
HOW THE HELL DO U RECALIBERATE IT OR DO ANYTHING IF IT WONT RECNONIZE FULL BRAKE TO GET TO ALMOST ANY STEP YOU NEED FULLL BRAKE AND IT WONT RECNOZIE IT IKM TRYING TO ASK HOW THE FU** TO RECALIVERATE IT... sorry for caps i wrote that whole thing in it and not relizing and i don't feel like righting it over
RE: Mamba help
idk, just try to use the controller as it is...
RE: Mamba help
ORIGINAL: flyingjato3.3 TO RECALIVERATE IT... ok, try to take all of the batteries out of everything, take the crystals out of the Rx and Tx. make sure the crystals are correct, put all batteries back in. then try. is it possible to have a faulty Rx, Tx, and ESC? yes. is it likely, no. i am the WIZARD of user error, so i understand thi whole "user error" feeling, and it's defeat. take your time and try EVERYTHING. you will get it. :thumbup: |
RE: Mamba help
Get the Castle Link and update the software on the ESC.
RE: Mamba help
I have the castle link..so use the controller where nothing will work except the steering becuase it isn't caliberated correctly? SMART idea.. OMFG im not an idiot I can follow simple directions it was caliberated incorrectly....all I am asking to do is how to recaliberate a controller ?
RE: Mamba help
Maybe you should contact Castle Creations directly. Seeing how none of us have been able to help you.
RE: Mamba help
Ok thanks CC hasn't answered me yet so im about to go and use my spektrum 2.0
RE: Mamba help
Increase the endpoints on the throttle and brake to 125%, and make sure your slider (either "A" or "B" near the trigger/wheel) is also out to 125%. Throttle should be in normal. You should be good to go after that. Let me know if it's still a problem.
