micro-t mesh.
when i first revieved my micro-t and tried to drive it it went about a foot and then stoped, however it was still making noises like the motor wanted to spin. so i checked the mesh and noticed the spur gear is worped and bent. so when the pinion gear spins the mesh goes from almost scippid on one side of the spur gear to being so tight it won't even spin (the reason it only went a foot) on the other side. so i talked to my LHS because i noticed theres nothing to hold onto while youre taking of the nut that secures the spur gear and he said the only thing you can do is hold that nut and spin the rear tires but when i tried that it poped out the out drive.
