new to the game
getting a mini quake and looking at a motor with 4000kv & 200w output with a 40 amp esc, would this combo be alright for some speed and decent torque? not looking to spend $200 on the mamba....
RE: new to the game
It will be as long as the motor has the correct shaft size (2.3mm or 3.2mm) and the esc is meant for a car/truck. I've never heard of a 40amp car/truck esc unless its a no-name chinese esc. If its a plane or heli esc, I don't suggest using it.
Btw, the 1/18th scale mamba set-up is only $100. You're probably thinking of a mamba max...which is for 1/10th scales. Although the mamba motors are not good for the MQ (too small), the mamba 25 esc is a great choice. |
RE: new to the game
ORIGINAL: pvt_pile Btw, the 1/18th scale mamba set-up is only $100. You're probably thinking of a mamba max...which is for 1/10th scales. Mamba Max = BIG TRUCKS Mamba (Comp, Comp X...), = SMALL TRUCKS (aka, what you have) Hope that helps, now if only they made it easier:) |
RE: new to the game
Mamba for 1/18th's is called Mamba 25 :)
RE: new to the game
ORIGINAL: bigairlife Mamba for 1/18th's is called Mamba 25 :) - CM = Castle Motor - 20 = can diameter of 20mm - XX = the Kv of the motor. So a 6800kv = CM2068. |
