RCU Forums
-   1/16th, 1/18th, Mini & Micro RC Cars (https://www.rcuniverse.com/forum/1-16th-1-18th-mini-micro-rc-cars-235/)
-   -   Mamba Programming Problem (https://www.rcuniverse.com/forum/1-16th-1-18th-mini-micro-rc-cars-235/6830793-mamba-programming-problem.html)
dtacmed 12-31-2007 09:28 AM
I just installed a Comp Kit in my Mini LST. Heres the problem. When I go into the programming mode it may let me set the first 2 settings then it just ends programming itself. It won't let me go thru the programming setup without stopping on it's own. Any Ideas?
KRO 12-31-2007 09:51 AM
RE: Mamba Programming Problem
Sounds like you are not in "programing" mode and its just calibrating too the controller .
When you turn on the ESC , hold the throttle down till it beeps and continue to hold the throttle down till it enters programing mode , it should start to beep slowly (beep, long pause then another beep) you should be at the first program option then .
dtacmed 12-31-2007 10:02 AM
It goes into the programming mode. I hit full brake to answer no and may get through the first setting then it just exits on it's own.
t9dragon 12-31-2007 01:07 PM
Do you have the Castle Link?
