Need Propulse Help!!
I have purchased a refurbished propulse from ebay, and have heard some horror stories from contacting megatech and want to know what to do. When I give a full throttle on it it just binds up and won't run, but if I give it slow gas and increase it works fine. Sometimes I have times where I am running it and I let go of the gas and it won't stop turning or stop going foward. I don't know what it is. I am running my own custom battery pack and that is the only thing on it. It could be the 15 degree weather I think too. I have one more question and that is the auxialary jack on the receiver how would a 2 prong fan go into it since you don't usually see 3 pronged fans?
Please help! |
RE: Need Propulse Help!!
ohh, is this "custom" pack the AA or AAA idea you had ??? It holding a turn or throttle sticking is a sign of batteries being too weak. My guess is your idea didnt work, and its not supplying the juice the model needs. Like I told you when you asked about using AA or AAA batteries.
Car is fine, get a pack meant for R/C and you'll be fine. Look around at some Radio shacks. Some still have propulse parts left over...and are willing to sell them fairly cheap to get rid of the stock they have as they arent selling them anymore. Where in Mass are you ? Batteries arent that expensive....I could keep an eye out for a deal on a pack and charger for you if you want. |
ORIGINAL: supercharged347 ohh, is this "custom" pack the AA or AAA idea you had ??? It holding a turn or throttle sticking is a sign of batteries being too weak. My guess is your idea didnt work, and its not supplying the juice the model needs. Like I told you when you asked about using AA or AAA batteries. Car is fine, get a pack meant for R/C and you'll be fine. Look around at some Radio shacks. Some still have propulse parts left over...and are willing to sell them fairly cheap to get rid of the stock they have as they arent selling them anymore. Where in Mass are you ? Batteries arent that expensive....I could keep an eye out for a deal on a pack and charger for you if you want. |
Nope, thats a sub c pack...its too big to fit in the pro pulse. Thats not meant for 1/18th scale cars. Most batteries for 1/18th scale will fit. Its what they call 2/3A size cell pack. The propulse ones look like this http://www3.towerhobbies.com/cgi-bin...?&I=LXSMG8&P=7
But you can also use ones that have all six cells together unless you do the twin motor conversion |
You dont really have to get one from radio shack, just make sure its a 2/3a 6 cell pack and you should be fine. If it has a different connector on it, you may have to switch it though.
As for tracks I dont know out your way. I know there is one in Fitchburg Ma....and a friend and I made a small clay one out back his house in Ware Ma. |
There is a track in RI but its indoors and more for mini-z's and xmods, also a few out in swansea, warwick, and a few others. THe one in fitchburg does look really nice though:D Going to have to buy the propulse pack or go to my lhs i guess. Could the batteries also be the reason for when I hit the gas it doesn't move, it only stutters? I might go to walmart find a cheap r/c with a nice battery pack and use that lol:)
Dont do it. Walmart will not have a battery meant for it.
I have a spare one of this charger new I could sell ya http://www.radioshack.com/product/in...entPage=search As for batteris, I would either go to a hobby store or get one meant for it from Radio Shack. and yes, your car is studdering under high throttle, cause the batteries cant do it. |
I am low on $$$ so I will just get the propulse battery for now and see what happens after, thanks for the offer though.
you can get this battery without charger
http://www.radioshack.com/product/in...ductId=2350306 1400 mah capacity. the charger you get in this deal with the 1200 mah takes 10 hours to charge......it sucks. lol. Just warning ya. http://www.radioshack.com/product/in...ductId=2363328 |
take your servo's apart and spray with WD-40.
What about the auxiarly, I heard you use it for fans but how does a two prong fan go into a 3 prong receiver? I know 10 hours to charge [&o] Think I am going to keep looking though
Did some more searching and found a towerhobbies quick charger and battery! http://www3.towerhobbies.com/cgi-bin...?&I=LXJC33&P=9 http://www3.towerhobbies.com/cgi-bin...?&I=LXJA83&P=M
If ya read that, it uses sub C cells....that mean the pack is physically TOO big to fit the pro-pulse, and 90% of the other 1/18th scales out there.
Finding a non sub c cell battery pack is harder than I thought but I am not sure if this is a non sub c cell because it doesn't mension wether it is or not? I am asuming if it says nothing about sub C cells I can use it. http://www3.towerhobbies.com/cgi-bin...?&I=LXHUJ8&P=0
that is way to big fro the propulse get packs that fit the rc18t
yea, one thing that gives it away....its a 1800 mah pack, and its a nicad (nickel cadium). Even a Nimh pack at the size we use wouldnt be that high. They top out around 1500 mah. nicad lower, I think under 1000 mah.
I am pretty sure I know what I will do now, thanks for the help.
MC201 |
http://www.cheapbatterypacks.com/mai...r=63&model=421
if you order form these guys you need to change the plug to a better one |
ORIGINAL: musclecar201 I am pretty sure I know what I will do now, thanks for the help. MC201 So whats your plan ? I hope you are going to get a proper pack, so you can see what the car will really do, and enjoy it. |
After talking it over with my grandfather who races airplanes and boats he helped me to explain what I really needed and I found what I needed, http://www.horizonhobby.com/Products...rodID=LOSB1206 http://www.horizonhobby.com/Products...ProdID=DYN1425 and it is not to expensive and won't break my budget so if I break a shock tower.
Do i need any special adapters to fit the propulse connectors? |
Yes, that battery will work, but you will need to either change the connector on the battery, or the one on the speed control. So you'll have to decide wich you want to change, and buy one. connectors dont usually cost much. Another thing you could do is go to a local hobbystore and they could help you out.
What connector would I need from either radioshack or horizon hobby? because dont the rc18 losi micro t and propules have the same connector?
Like buy a bunch of micro dean plugs? |
ORIGINAL: musclecar201 What connector would I need from either radioshack or horizon hobby? because dont the rc18 losi micro t and propules have the same connector? Like buy a bunch of micro dean plugs? http://www.horizonhobby.com/Products...ProdID=WSD1300 2 sets of these and someone to soder it for you |
ORIGINAL: zjwhitrock ORIGINAL: musclecar201 What connector would I need from either radioshack or horizon hobby? because dont the rc18 losi micro t and propules have the same connector? Like buy a bunch of micro dean plugs? http://www.horizonhobby.com/Products...ProdID=WSD1300 2 sets of these and someone to soder it for you |
have ya ordered ? Let us know how you make out.
