E Revo Wheel shake
My E Revo has been pretty solid so far (one broken control arm).
However I noticed when my car flips over now the front wheels are shaking. What causes this? Loose servo? Thanks guys- |
RE: E Revo Wheel shake
Mine does the same thing as does my son's. It's just a radio/servo issue (typical RTR radio/servo issue) and as soon as they're back "on all fours", all is good and nothing to worry about. It is weird the way the front wheels wiggle when upside down though!
also maby your tires arnt in balance mine does that as well but only at full throttle
Mine does the same thing. I'm switching to 2.4ghz eventually to cure the problem.
Cool. Doesn't sound like its a problem then.
Good to know. |
It's actually the stock servo. Mini did it, but a Hitec HS-82MG completely fixed the problem.
ORIGINAL: squeaky penguin It's actually the stock servo. Mini did it, but a Hitec HS-82MG completely fixed the problem. |
