Speed Pinion Problem...
I have a small problem with the speed pinion i am trying to install in my e revo 1/16 vxl...
I have the stock pinion exposed, and i put in the right sized allen key (wrench) but every time i try to turn it, it just slips... its like the the set screw on the side of the pinion gear is too tight. THanks<br type="_moz" /> |
RE: Speed Pinion Problem...
Any help or ideas why it would be doing this would be great.
umm, your screw or wrench is stripped.
Yeah, i figured that, but when i used a different allen key it worked fine.. i guess it was just the cheap allen key i was given.
yes the traxxas wrenches suck. I'd invest in a pair of quality drives, i have been using these for 2 years now with NO problems, never stripped anything with them: http://www.amainhobbies.com/product_...-15-20-25-30mm
Ok thanks.<div>I'll look into a pair of buying something like that. </div><div>
</div><div> </div> |
