PROP-JET BINGE
#126
RE: PROP-JET BINGE
Here is a link to it till they reject it then I will move it to scratch build forum. [link]http://www.rcgroups.com/forums/attachment.php?attachmentid=3633837[/link]
#128
RE: PROP-JET BINGE
They are fun There are guys now close to 200 mph heck by now the might even have busted out I have not been paying close enough attention to the forum lately. Im going to have a bolt on wing which once I cut it open for the wing will leave me a lot of room to add ducting on the next if I build it plus room to install fan and radio gear. I think I also am going to build in a rack in the back to support the full flying stabs. It will tie wrap around the top and tie into the rest of the bulk heads and all the top sheeting hope I can do it so as it will be strong enough to keep from twisting. It will have a hatch which will come of just under the stabs to work on that area and if I find that I cannot get it strong enough I will just seal the bottom back up after all the servos and stuff is installed.
