Go Back  RCU Forums > RC Airplanes > "1/2 A" & "1/8 A" airplanes
Reload this Page >
Need Meemory help- built up ace wings
"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Old 05-24-2011, 01:55 PM
ebeneezer3
ebeneezer3's Avatar
Default Need Meemory help- built up ace wings
I'm pretty sure that some where I saw plans for built up "Ace foam wings". I have recently gotten RCM plans for the sopwith triplane. The article supplied says finished weight is 3lbs. I would think 3 built up wings would be lighter. Does anyone know where I can find them? I DO shudder at building 3 wings but 3 lbs. seems a bit much for a .15
Old 05-24-2011, 09:27 PM
Jaspur_x
Default RE: Need Meemory help- built up ace wings
Try searching the " ace whizzard built up vs foam", I think thats thethread you mean.
That does sound a little heavy, but I don`t fly anything even close to half that large so it should sound heavy to me , so don`t just take my word for it lol
Old 05-24-2011, 10:04 PM
sewflynwa
Ebeneezer3,
Try here. (Hope this link inserts right)
[link]http://my.pclink.com/~dfritzke/[/link]
The Pacer uses the tapered wing, but can easily be converted to the straight wing.
Sewflynwa
Old 06-02-2011, 06:23 AM
cortacesped
I think Andrew Donatelli drew plans for a constant chord Ace wing.
Claudio
Old 06-02-2011, 08:09 AM
Andrew
ebeneezer3 -
Drawing your own set of plans for a constant chord wing is incredibly easy.
The ACE foam wing has an airfoil close to, if not exactly, a NACA2415. But your plan set from RCM should have cross-section that you can use. The original wing had a chord of 5.5" IIRC - just make sure your cross-section is very close to 5.5" . You can use this cross-section to make your rib template. I use counter laminate (formica), but you can use plywood or thin aluminum. Draw a line from the tip of the leading edge to the trailing edge - this is your chord line. Your spar notches will be made 90 degrees to this line. Pick stock for the leading edge; 1/4 x 1/2 should work nicely. Choose trailing edge stock that best matches your airfoil. I would be inclined to use 3/16" square for the spars and 1/16" spar webs 2/3 of the way out from the center section. You won't need any on the outer bays, except possibly the last. I'm lazy, so I don't cut my webs to fit between the spars; I just glue them to the sides. It gives more glue area and is quicker.
Now for the plan. I like freezer paper for drawing. Draw parallel lines 5.5" apart for the front of the LE and back of the TE. Draw another parallel line for spar positioning. Draw a series of lines perpendicular to the spar lines for rib alignment. You will probably want the sheet the center section so your center ribs will need to be cut down the thickness of the sheeting. You can use Dick's Dream planset from Dave Fritzke's site for an example. I generally set my rib spacing between 2.75 to 3.00". Wing plans really don't need to be detailed, just enough lines to get everything lined up.
You can probably figure a wing panel at 17" with tips taking up 1/2" each.
andrew
Old 06-02-2011, 06:29 PM
ebeneezer3
ebeneezer3's Avatar
Sounds like it'll work. Thanks I'll try it
Old 06-02-2011, 08:23 PM
Jaspur_x
Just  another thought,  Clancy aviation wing ribs are spaced a bit farther apart than it looks like they should be. I have  made modified wings for several planes that look odd to say the least, but fly well.
 Sine you are trying to save weight, maybe space the ribs a little farther apart than onventional wisdom would tell you to. As long as you have good constrution ( good leading, trailing edges, anmd good spars) you should be able to get away with it without losing strength, or lift..
Other than that little tidbit of info. , I would go along with Andrew`s suggestion, thats pretty much how I do it.
Old 06-03-2011, 05:23 PM
skaliwag
skaliwag's Avatar
Here is a scan of ribs very close to the Ace foam wing. I think I would put another spar (1/8 X 1/8 ) between the main and the L/Edge. Also a shear web.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
