Ace High Glider..
RE: Ace High Glider..
Dave Fritzke must have it somewere in his files!
[email protected]
He has lot of classic designs and Ace plans:
http://my.pclink.com/~dfritzke/index.html
[email protected]
My Feedback: (50)
CA
skaliwag,
Just out of curiosity, why do you want plans for an Ace High - to build and fly one?
I had and Ace High back in the 70's. It was very quick and easy to build and easy to learn to fly with. I think it was a fine trainer, but not much else. Flying it was pretty much and up and down affair as I couldn't even get close to catching and holding a thermal with mine.
Panic over with the plan search. My attic holds many spiders and secrets.
Silvaire. For your curiosity ... I need a trainer in my stable. I learned with an Ace High / Medalion .049.
And you are right about Up.. Down. Except on a very hot or windy day.
Stay tuned for a winter project.
Mine is converted to electric, added elevator. Also added wing area with trailing edge stock, as is suggested in instructions.. Thermals just fine. I have the "plan", it has full size frames and sides, the other views are 1/2 scale I think.
http://www.youtube.com/watch?v=sP7mvyXZSE0
MN
skaliwag,
It is one plan that I started to "cad-a-fy" and never quite got finished. I have 2 of those kits knocking about.
Super easy to build. I should scan the plan and zip it off to Steve at Outerzone.co.uk.
Dave
Dave
MN
I'll just finish it off with plans showing a NACA 2415 airfoil built up wing.
(Although it's possible to get those foam wing cores on flea bay from "mcclain1717"
for a reasonable $10/pr)
Dave
http://www.ebay.com/itm/ACE-Mini-Foa...item484ee30615
Dave
MN
I sent a scan off to Outerzone, I'll update this post with a link when it's up there.
The plans are 3/4 size, so print at 133%-134% to get full size. (100/75=1.3333).
Dave
And here it is:
http://www.outerzone.co.uk/plan_details.asp?ID=5255
Dave
And here it is:
MN
I just sent him a scan of the Ace kit plans. (attached)
I am not familiar with the plane you posted (M-Sailer)
Dave
At Outerzone:
Dave
At Outerzone:
