Flight Pack with Micro JST Connectors
TX
Hello,
Quite a while back I bought a Spektrum AR6300F DSM2 Nanolite Flight Pack.
It has a receiver and 4 servos. well now I'm preparing to build a few small / light rubber power to RC converted kits and I wanted to use this flight pack.
The receiver has these funny looking micro JST connections.
I haven't seen them before. I'm wondering what speed control would have a plug like that, and what battery pack .
I'm planning on building a 30" Herr, Ryan STA. It's a stick and tissue, rubber power design, so I need to keep as light as possible.
Jim
Jim
RE: Flight Pack with Micro JST Connectors
Jim, http://www.bphobbies.com/view.asp?id=A0320122 is one of several online stores where you can purchase mini JST connectors. ESC's and most LiPo batteries do not come with connectors, you have to supply them.
Gene
Gene
When you buy your connectors, sold with pigtails attached, be sure to double check the polarity - don't just rely on color matching. If the pins need to be reversed, the connectors have a small tab that can be lifted with the point of an Exacto knife and the pins slipped out, then re-inserted.
Don't ask how I found out. [:@]
TX
Thanks guys,
I went to the BP site mentioned above and even the little 5 amp speed controller looks like it has the normal receiver connection.
http://www.bphobbies.com/view.asp?id...1&pid=E2034774
I want to be as light as I can so I don't want to just use adapters. I didn't see any speed controllers already rigged with micro JST, so I'm guessing I need to cut that off and solder on the right one?
Looking at batteries yesterday, I saw some 2 cell lipo's that looked like they had one little red 2 wire connecter (JST?) and another one that looks like the micro JST, but I thought that was just a balance plug??
Jim
Jim
ORIGINAL: scattermaster
Most 2s lipos rated at 1000mAh and under will come with the 2-wire JST connector (usually red). The white micro-JST is your balance plug and cannot be used in place of the discharge connector. Depending on the speed controller, some come with battery plugs and some come without. Since your lipos will likely already have the JST battery plug, the simplest approach is to get matching JST plugs for the ESC. Unless you want to buy pins and a crimp tool (hardly worthwhile), just get the JST with pigtails and splice to your ESC. You can always shorten the wires to save weight and voltage drop.
