Go Back  RCU Forums > RC Airplanes > "1/2 A" & "1/8 A" airplanes
Reload this Page >
Anyone ever have a Webra .09/1.5cc R/C side exhaust motor?
"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Old 09-22-2014, 07:37 AM
DeviousDave
Default Anyone ever have a Webra .09/1.5cc R/C side exhaust motor?
I've never seen one of these before, while visiting RocketRob 2 weeks ago in San Fran he gave me three of these engines to take home.
Are they good runners? They seem 'sturdy', which is perfect for a project I have in mind that needs two heavy engines as there essentially isn't a nose on the airplane.
Old 09-22-2014, 09:37 AM
Mr Cox
Mr Cox's Avatar
The Webra 1.5cc Sport is unfortunately a bit anemic. It is a simple cross-flow design with a flat head piston...
I don't remember exactly what mine did but expect around 14-15000rpm on a 7x3 prop, and use plenty of castor in the fuel.
The Webra Speedy 1.8cc and the 2.0cc (ABC) with the rear exhaust, are much better.
Old 09-23-2014, 04:34 PM
DeviousDave
So, about like an OS .10FP then?
Old 09-23-2014, 10:54 PM
Mr Cox
Mr Cox's Avatar
No, they are weaker than a typical .07 engine...
The OS .10FP will make around 16000rpm on a 7x4 prop, as a comparison.
Old 09-24-2014, 06:53 AM
DeviousDave
That's not promising...
Old 09-24-2014, 01:02 PM
Mr Cox
Mr Cox's Avatar
No, it was a real disappointment when I first ran it. I also had a look inside, it is a simple crossflow design, but they forgot to put the important baffle on the piston...
Perhaps it began as a diesel design and then also offered as glow, I don't know.
The engine to have in this size from webra is the Speedy 1.8cc or even better 2.0cc;
Old 09-24-2014, 04:59 PM
JohnAV8R
The Webra Speedy 1.8 cc (MAS 7x4) is a fantastic little engine. On my "Wild Thing" it easily keeps up with an Enya .15 (2.5 cc). It is lighter than an MVVS 2.0 cc and has the same power. The only disadvantage (for me anyway) is that it uses its own glow head. I have drilled and tapped the old glow head for a standard glow plug. Not much power was lost.
Name:	Webra 1.8 speedy- (12).JPG
ID:	2044347   Click image for larger version
Name:	Webra 1.8 speedy- (5).JPG
ID:	2044348   Click image for larger version
Name:	Webra 1.8 speedy- (11).JPG
Old 09-26-2014, 07:32 AM
dennis
My Feedback: (90)
The Webra 12 that I have is a jewel. Rear exhaust and ball bearing and pricey at $129.95 when I bought it. The muffler was extra as it did not come with the engine. Power was there and would keep up with most of the decent sport 15's of the day. Somehow or another I lost the needle valve in storage and after 2 years of trying to get a replacement I gave up and converted it to a control line engine. I really need to find a design that moves me to get this little jewel back in the air
ID:	2035156   Click image for larger version
Old 10-05-2014, 03:51 AM
Mr Cox
Mr Cox's Avatar
I got a little curious about the engine again, so I dug out my 1.5cc from the bottom of a shoe-box and gave it a little bench run...
I have worked a little on the crank inlet before and also added an muffler pressure fitting, but appart from that it is all stock. It is not quite as bad as I remembered, on 8% nitro and 25% all castor I get the following numbers;
APC 7x4; 13400 rpm (feels a little overloaded at full throttle)
APC 7x3; 16200 rpm (good throttle response)
It idles down to about 5000-6000rpm, but it is not possible to tune on the airbleed with the engine running. It is also best to wear a glove, as the airbleed screw tends to cut the finger tip when flipping the engine...
ID:	2037358   Click image for larger version
Old 10-05-2014, 08:14 PM
JohnAV8R
What about if you turned the carb around and had the air bleed screw at the back and out of the way? I have a small engine set up that way, but I am not sure if it came that way intentionally, or in error.
Old 10-05-2014, 08:20 PM
ffkiwi
I don't think it makes a huge amount of difference-though I'd expect to see a very slight difference in setting between a front facing airbleed and a rear facing one-due to the ram effect of the prop slipstream-but given we are talking at idling speeds this would be fairly small...I have seen over the years some engines with the bleed opening on the rear face of the carb.
ChrisM
'ffkiwi'
Old 10-05-2014, 10:02 PM
Mr Cox
Mr Cox's Avatar
In terms of function the airbleed could well be facing backwards by rotating the whole carb 90°, I have done that on other engines.
On this engine though the carb is very asymmetric in shape, it doesn't show so well in the pictures above, but the section with the airbleed screw is sitting on a bulge on the carb. This bulge puts the screw very close to the prop, and it will also hit the cylinder if one rotates everything by 90°.
Old 10-06-2014, 04:03 AM
Mr Cox
Mr Cox's Avatar
I just checked my computer for some more info and found a parts diagram with the different versions, it did come as a diesel, glow (airplane), and car engine (larger head). The carbs seems to have varied over the years, the early ones look a bit like the MVVS ones, while I have the later version which is common with the 1.8 and 2cc "Speedy" engine.
I have a used airplane engine and a NIB car-engine, but none of the diesel ones...
ID:	2037693   Click image for larger version
Old 10-06-2014, 07:00 AM
Mr Cox
Mr Cox's Avatar
After a bit of "googling" I found a picture of the diesel version too. The pretty anodizing of the head should be a warning sign. Any engines that need pretty colors in order to sell, usually don't deliver much in terms of performance...
Name:	WEBRASPORT diesel.jpg
Old 10-06-2014, 07:21 AM
JohnAV8R
" Any engines that need pretty colors in order to sell, usually don't deliver much in terms of performance... "
Well, I guess I'm guilty as he** on that note. I've always been a sucker for the anodized muffin colours.
John
Old 10-06-2014, 10:30 AM
Mr Cox
Mr Cox's Avatar
I feel a bit guilty now about the carb, I hadn't actually tried to rotate it, it just looked impossible. Turns out that they have given just enough of chamfer to the bulge to allow for a rotation...
So with a new hex screw installed, instead of the slotted stock one (a regular M2x8 machine screw) and with the carb rotated 90°, it will now be possible to tune on the low-end while running the engine, great!
Old 10-07-2014, 03:34 AM
Mr Cox
Mr Cox's Avatar
I just realized that these engines are very similar to the LST engines. I have one of them in diesel form, but I know very little about them. They are/were made in Lithuania and it certainly looks like they were inspired by Webra, or possibly the otherway around...
Same thing here though, one single transfer port (opposite to the exhaust) and no baffle on the piston. The muffler is kind of cute though...
ID:	2038203   Click image for larger version
Old 10-07-2014, 04:36 AM
aspeed
aspeed's Avatar
Nice muffler, it likely seals good, and there is a nipple on the back so an extension won't fall off.
Old 10-07-2014, 09:37 AM
JohnAV8R
Default air bleed at the back
size--next to a Pee Wee .020
LH diesel has air bleed set at the back
RH diesel has air bleed at the front
ID:	2038268   Click image for larger version
ID:	2038269   Click image for larger version
Old 04-15-2015, 05:52 AM
jetpack
jetpack's Avatar
Name:	Webra Sport 1.5cc .09ci.jpg
ID:	2089251   Click image for larger version
Name:	RC 1006-116F.JPG
ID:	2089253   Click image for larger version
Name:	Ersatzteile Sport 1,5.jpg
ID:	2089254   Click image for larger version
ID:	2089255   Click image for larger version
Name:	Engine and Parts Listing.jpg
ID:	2089256   Click image for larger version
Name:	Carburetor and Parts Explosion.jpg
ID:	2089257   Click image for larger version
ID:	2089258   Click image for larger version
Name:	Webra Fuel & Prop Specs.jpg
Old 04-20-2015, 11:23 AM
MJD
MJD's Avatar
When you turn the carb 90 degrees, do you recommend putting the needle valve into the prop arc, or into the cylinder?
Agree on engine colors- but there are a few exceptions. The purple West .50/.52 for example. Hmm, what else now..
Old 04-20-2015, 11:45 AM
Mr Cox
Mr Cox's Avatar
Ooops that's a really bad/silly typo, it should read 180° degrees of coarse...
Or you would have to rotate the whole engine the reminding 90°...
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
