Go Back  RCU Forums > RC Airplanes > "1/2 A" & "1/8 A" airplanes
Reload this Page >
Ply Eggshell Fuselage -"Lil Miss Butter Knife" TD .09 4ch Knife Edging Stunt Plane!
"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Old 01-06-2015, 07:35 PM
Pond Skipper
Pond Skipper's Avatar
The second former has a cut out for the 2 oz tank and the bubble top for the breather tube.
The side sheets of thin ply will be over cut by a percentage joined at the top with thick slow cure CA zip kicked to keep the seams at the top and bottom stringers nailed down while CA naturally cures to the formers and to the 2 center stringers. Will finish up with more zip kicker on the bottom seam while the whole lot sets up. I will make poster board templates to insure the side sheets are set up to fit like a glove.
Old 01-06-2015, 07:38 PM
Pond Skipper
Hey Mike I wish lol ... nope will just cut them out with a jig saw. Lucky by design there is very little in parts due to the ply skin making things very rigid in the end.
Old 01-06-2015, 08:24 PM
Pond Skipper
Mike I can mail you templates or you can fudge off the progressive online single page plan thats forming as a jpg.
I have made room for the elliptical wing next. The firewall is big enough for any 10 or 15 size engine.
Name:	27.25 inch Concept Size Formers XXX.JPG
Old 01-06-2015, 08:30 PM
Pond Skipper
Even my OS 26 Surpass fits / inverted with the firewall moved back an inch looks good.
Old 01-06-2015, 09:28 PM
Pond Skipper
Ok getting close to finished few things left to mull over.
Old 01-07-2015, 12:34 AM
  #31
combatpigg
combatpigg's Avatar
Paneling the bones looks like a tough job..!
I seem to recall reading that the P-38 or P-39 was covered with steamed plywood.
I'm trying to imagine how 1/64" ply would react to that..it would tear like tissue I think.
What once looked like a lifetime supply of 1/64" in my wood bin is no longer there.
I know I'll get a case of sticker shock when I see what it costs now..plus what an ackward item to ship just 1 of.
Old 01-07-2015, 01:12 AM
  #32
Pond Skipper
My hobby shop has some on hand - 1/64x12x48'' last time I was there I almost bought a sheet $31.44 a pop enough for 2 planes with scrap to do the center sections of the wing. 1/64" (0.39mm)
Single 48" sheets here for$22.62 but you pay for shipping.
http://www.abellhobby.com/5480-Birch...-p/mid5480.htm
Here you go;
http://www.ebay.com/itm/Model-Plywoo...ht_2195wt_1106
If you buy 6 sheets at a pop / free shipping $169.97 / 28.33 ea. / 14.16 per plane in this case.
Model Plywood 1/64x12x48" (6) RMXR7870 REVELL/MONOGRAM
Old 01-07-2015, 03:12 AM
  #33
Pond Skipper
Additional elements added to the plan
Old 01-07-2015, 06:57 AM
  #34
skaliwag
skaliwag's Avatar
[QUOTE=Pond Skipper;
I had to do a search tonight for a 1.25in spinner a perfect size for the TD .09 so I had to buy from the far east.
The prop bolt for the 09 is a 6-32 I will have to make a adapter for what looks like a 2.5 or 3mm spinner bolt.
A 6-32 X 1/12 stainless cap screw with head cut off might be the ticket used with a 4mm collet made for an E-motor.
BTW....Nice design / concept
Old 01-07-2015, 11:45 AM
  #35
Pond Skipper
Thank you Skaliwag!!!
CP and others I went to the hobby store today and found a sheet of 1/32 x 12 x 24 which will be a the way to go.
The fuselage is only 24in as the rudder doesn't count nor does the spinner. That sheet only cost me $8.69 I did buy 1 sheet of the 1/64 x 6 x 12 for the wings center section to skin over the balsa for protection when the wing is held down. The 1/32nd is thick enough to hold up as a egg shell type design and will eliminate additional spruce stringers typically 8 stringers will only need 4 1/8in stringers so will have to reduce the notches in the formers. As you can imagine the frame only needs to hold true long enough to skin it with the 1/32nd after that its a brick house.
If I was building a 40 to 60 size I would want 1/4 stringers.
Old 01-07-2015, 12:05 PM
  #36
combatpigg
combatpigg's Avatar
IIRC, I paid $50 for a 24" x 48" sheet of 1/64" about 10 years ago at the LHS along with some other really expensive little "necessities"....so I remember that as a very guilt ridden trip from the store.
That guilty feeling is pretty awful and it usually lasts a good 10 minutes or so while driving home.
I just did a quick estimate of what it would cost to sheath a 2000 sq foot roof with 1/64" to a thickness of 7/16".
Based on $63 for a full 4 x 8 sheet of 1/64" x 28 sheets to reach the desired thickness = $1764 per 4 x 8 panel.
It requires 62.5 panels x $1764, so roughly $110,000 or so.
Old 01-07-2015, 12:24 PM
  #37
Pond Skipper
OOooouchiee!!! you can get the same sheet now for $22.62 I only feel guilty if I don't go buy due to lazyness.
Ok revised the formers back on track!
Old 01-07-2015, 07:50 PM
  #38
hllywdb
hllywdb's Avatar
I just use the contact paper they make for the kitchen drawers with the wood grain pattern. $3.99 a roll and it looks just as nice. Just don't fly it in the rain.
Old 01-07-2015, 08:20 PM
  #39
skaliwag
skaliwag's Avatar
Any experience with this stuff over foam?
http://sigmfg.com
Product code
SIGRH001
SIG RHINO HIDE 1/64 X 24 X 36
Old 01-08-2015, 12:54 AM
  #40
combatpigg
combatpigg's Avatar
I used it many years ago.
IIRC, it seemed too heavy for anything but large models.
It might have been Bill Evans who specified it for his Polestar...?
Old 01-08-2015, 04:15 AM
  #41
Pond Skipper
Rib layout completed:
Old 01-08-2015, 05:56 AM
  #42
aspeed
aspeed's Avatar
The Rhino hide sounds like oriented strand board or something similar? .010 or .015" Lexan may be a good choice too. Sure is tough stuff on the rc cars.
Old 01-08-2015, 07:19 AM
  #43
Pond Skipper
Last night I bought a smaller version of the 1/9th scale Bridgette - Meredith cuts out some width and weight will still be a tight fit with the narrow fuselage.
Once it comes in I imagine I will have to resize the former lay out to shoehorn her in.
Name:	1 9th scale.JPG
Old 01-08-2015, 11:22 AM
  #44
MJD
MJD's Avatar
Ooh, cute. So, you'll have her head pivoting with the rudder servo will you? And whatabout adding a little 1.5 gram linear servo to wink her eyelids? LED's in the eyeballs? C'mon man.. bling it up!
Old 01-08-2015, 12:44 PM
  #45
Pond Skipper
Lol Mike the rudder servo thing is easy to do in fact the best is having pilot on a ball socket for elevator and rudder.
If 1/3rd scale eyelashes might be seen least one eye set up to wink on a slow fly by.
If your pockets are deep one could go with this 1/6th scale pilot:
Name:	Pure Scale Fem Pilot.JPG
Old 01-08-2015, 02:10 PM
  #46
MJD
MJD's Avatar
It's easier to try goading someone else into doing more work on their airplane than it is for me to make any progress. Actually I had a productive evening last night , I dedicated the evening to experimenting on the laser to get the best cut possible on 1/8" lite ply - different focal length lenses and settings. I have cranked out myriad parts and had good fun but it has all been new toy whee factor stuff (which at one point included engraving a Babe Bee drawing onto a tortilla). I think it's time to get serious ..
Old 01-08-2015, 04:54 PM
  #47
Pond Skipper
Yea lol for shame for shame..
I wanted to goad myself into flying the Skorch this weekend till rain sleet and ice told me to dream on.
Old 01-08-2015, 08:07 PM
  #48
MJD
MJD's Avatar
I plan to go flying next time somewhere around May 15..
Tomorrow looks like some fine building conditions:
Fri. afternoon
A few flurries
-12°C
Feels like -22
P.O.P: 40%
Snow: Less than 1 cm
Wind W 30 km/h
Wind gust 48 km/h
Humidity 66%
Old 01-09-2015, 12:50 AM
  #49
Pond Skipper
Yep looks like laser cutting time
Old 01-09-2015, 08:06 PM
  #50
Pond Skipper
Known weights:
207.5g / 7.32 oz
- Engine / prop
- RX
- 4 servos
- 2 oz round sullivan tank
- engine mount
- 1.8in dia golden age wheels 17.9g
Goal 17oz - 9.68 oz left to work with
Wheels came in also the servo's for a comparison with the 1/2A servo 7.8g vs 14.9g as shown with horn more than twice the torque. 42oz at 6v good for up to a hot 15 or sport 20 size engine. High impact type carbon gears, resistant to vibrations.
Details on this purpose designed narrow servo on page 1.
