little bumble bee
My Feedback: (66)
not sure on speed but guessing in the 125-130 range. hard to tell with such a small plane. i hacked it up pretty good putting this thing in the front of it. so lots of lost speed in the front. Prop is a tiny bit to much load straight and level but in a slight dive sounds like it picks up another 1000. this engine has been worked and has a really big carb. i need to run a bladder tank and thin lines. I have to baby it on the launch as a hard throw will kill it. i think we opened the carb up to 180-200. i can try to take a pic of rpm numbers if you like.
Whittling on the prop until you see a drop off in speed has always been the best way.
This is where having a radar to give instant readouts at the field would be handy.
Otherwise, the 4.2 x 4 is worth trying.
My Cyclon has a .157" intake at it's narrowest point, so your .180 - .200" is definitely large enough.
The single most significant thing I ever did with an AME was the "Toad Mod"...where you raise the piston skirt and notch the crank's counterweight to create a unobstructed path for airflow up the forward boost port when the piston is near BDC.
I have this on favorites. It seems to have been down for a while, but is back again. http://www.toadsrc.com/engines.htm
